2manysubies Posted March 19, 2012 Share Posted March 19, 2012 Just pulled a learning view from my 05 LGTL before I install a bunch of mods, can someone interpret this for me? Or steer me to a link that explains this. Thanks in advance! http://i43.tinypic.com/345dc77.jpg Link to comment Share on other sites More sharing options...
iNVAR Posted March 19, 2012 Share Posted March 19, 2012 Looks healthy. Fuel trims are well within range +/- 5%. No learned knock anywhere. Happy modding! And happy reading! http://www.romraider.com/forum/topic4899.html Link to comment Share on other sites More sharing options...
nich0lai Posted March 19, 2012 Share Posted March 19, 2012 Looks great. Link to comment Share on other sites More sharing options...
2manysubies Posted March 20, 2012 Author Share Posted March 20, 2012 I am able to connect ECU to Learning view no issues, when I attempt to run RR logger I get "unable to connect to ecu, ecu unknown". Closed computer, started car first, let laptop boot with usb OBD cable attached still not working, have Vag com type cable on COM2 @ 4800 Baud, I gotta be doing something wrong. Any ideas would be appreciated. 05 LGT stock. laptop win XP sp3. Mac Link to comment Share on other sites More sharing options...
iNVAR Posted March 20, 2012 Share Posted March 20, 2012 Did you get the latest definitions? Link to comment Share on other sites More sharing options...
2manysubies Posted March 20, 2012 Author Share Posted March 20, 2012 Yes, I believe I do, attached is a PIX of the cable I'm using, link to the latest defs is on RR.com right? http://i43.tinypic.com/rtmfkm.jpg Link to comment Share on other sites More sharing options...
Adoniram Posted March 20, 2012 Share Posted March 20, 2012 You can get the latest ECU definitions here: http://www.romraider.com/forum/viewtopic.php?f=8&t=360 Download that, extract to the romraider folder. I assume you've verified that COM2 is the correct port for the cable? Does EcuFlash see your cable? btw, it's perfectly ok to post questions in the guide thread. That's what it's there for Link to comment Share on other sites More sharing options...
2manysubies Posted March 21, 2012 Author Share Posted March 21, 2012 Down loaded from your link, just the standard one not the metric, installed in RR directory, (removed old file as well)learning view still works, identifies car and ECU(like in first post) does not connect in ECU flash, (yes I picked the car from the list) it also does not connect in RR logger, says make sure cable is plugged in etc, cannot interface etc. I'm kinda lost, a week ago I removed all RR/ecu flash/learning view software and did a complete re-install, still no Joy. Mac using ecuflash_129 from original instructional Link to comment Share on other sites More sharing options...
iNVAR Posted March 21, 2012 Share Posted March 21, 2012 How long ago did you get that vagcom cable? I'm assuming it's fairly new. What drivers are you using? Try these if not already using them: http://www.crimetank.com/misc/CDM20602.zip Link to comment Share on other sites More sharing options...
Adoniram Posted March 21, 2012 Share Posted March 21, 2012 Sounds like you need to manually update those drivers. Do you know how to do that? In EcuFlash, in the bottom right-hand corner, do you see "No vehicle interface" or something else? Link to comment Share on other sites More sharing options...
2manysubies Posted March 21, 2012 Author Share Posted March 21, 2012 Invar, Cable is about a month old, driver signing is FTDI, driver name is ftser2k.sys, Com 2 checked again @ 4800 baud, I'll take a look at your driver recommendation. Adoniram, Yes, I'm quite computer literate, and my 21yo son is a freakin CPU wiz, I can't keep up with him, but since this program has been giving me issues, I've been letting him do the maneuvering within the directories. Yes sir, "No vehicle interface" with ecu flash. when I select the car, there are 2 2005-2006 wrx/lgt etc I tried both. I even tried a 2007, I know(2007) it's a cannibus car and I don't have a tactix cable, THAT it noticed, Bla Bla non canni Bla bla, which leads me to believe it is at least seeing the harness?? I'm out of guess's, I may consider a AP, all my mod parts are building up, just need a few more things, I really need to get this to work BEFORE the mods, heck you guys know where I'm coming from and thanks for the help! Mac Link to comment Share on other sites More sharing options...
Adoniram Posted March 21, 2012 Share Posted March 21, 2012 Ok, if EcuFlash is saying "No vehicle interface" that means the drivers need to be changed. You can do this by opening up Device Manager, right-clicking on the correct COM device, and updating driver. The steps are almost the same as they are here: http://legacygt.com/forums/showpost.php?p=3792501&postcount=138 The driver file is this: FTDIBUS.INF It is located in the EcuFlash folder, under another folder called "Drivers" If you and you are son are fairly computer savvy, you should be able to get through that. If not, lemme know and I'll see if I can get you some better step-by-step instructions. Link to comment Share on other sites More sharing options...
2manysubies Posted March 21, 2012 Author Share Posted March 21, 2012 No luck this morning, changed drivers as suggested ECU screen: [22:47:06.043] unable to open OpenPort device [ Serial ]. [22:47:06.043] unable to connect to vehicle interface. RR Logger does not work either Com settings correct, now com5 4800b no flow control(default) {frustration setting in} Any other ideas greatly appreciated (besides AP tuner at this point LOL) Mac Link to comment Share on other sites More sharing options...
iNVAR Posted March 21, 2012 Share Posted March 21, 2012 Hmmmm... wtf.... try this: 1) disconnect cable from laptop 2) open a command console 3) type: "set devmgr_show_nonpresent_devices=1" 4) type: "start devmgmt.msc" 5) in device manager, go to view->show hidden devices 6) delete ALL instances of the openport/tactrix/vagcom/whatever you want to call them drivers. you'll note that some of them are greyed out. this means that the device is not connected currently, but it shows that the software is install. this is the way to clear out the old software. after doing all of the above, reboot. THEN reconnect your cable, and install the drivers i gave you. hopefully that will work....? Link to comment Share on other sites More sharing options...
Adoniram Posted March 21, 2012 Share Posted March 21, 2012 In step 6, you should be looking under Ports (COM & LPT). This is what mine looks like after doing the above steps: http://i5.photobucket.com/albums/y175/academyracer/LGT%20flashing/dev.jpg Link to comment Share on other sites More sharing options...
2manysubies Posted March 21, 2012 Author Share Posted March 21, 2012 OK, mine looks similar except there is no communications port(yours is com5), I reinstalled the driver for the cable from one of the above posts, I have some info...first off, it didn't work again. Secondly, when I bought the car 6 month ago, it had 3 wires coming up from behind the dash by the drivers A-pillar, here's the PiX, I thought it might me a GPS or XM deal, but I bet the guy had a AP mounted there?? On the A-pillar, there are some wear marks in the interior cover about 3" above the dash surface, can't see it in this pic, cause I used Macro, I wonder where these wires go??? Here it is: http://i42.tinypic.com/34dr8tj.jpg Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 I had a vag-com that i tried to use with my friend's 05 lgt. I fought with trying to get it to work for weeks. I said fuuuuuuuk thiiiiiiis and bought a tactrix. Best purchase. If invar cant figure it out i dont think im much help Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 The wires look like its for some kind of accessory with an antenna but i HIGHLY doubt its related to your issues. Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 i'm scratching me head here. i hate troubleshooting stuff like this over the interwebbbs Link to comment Share on other sites More sharing options...
Ktmking250 Posted March 22, 2012 Share Posted March 22, 2012 iNVAR just saved me, if your going to do more ecu stuff id recommend ordering one while you try to figure it out. you might have your new cable before you figure it out, and then, from now on itll be a=easier and faster. just my 2 cents Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 After screwing with my vagina-com my friend loaded win 7 on his macbook pro and everything worked my laptop had win 7 home premium. I think it needs professional or something i dunno. Doesnt matter now. Link to comment Share on other sites More sharing options...
2manysubies Posted March 22, 2012 Author Share Posted March 22, 2012 Thank you folks for all your insight! Here's my plan, Try this with windows 7, I've got laptops with Windows 7 ultimate, that is something I can do tomorrow, so that's what I'll do. If that turns out unacceptable, I will make a decision between buying a tactrix cable(around $170) or press the "EASY Button" and go Cobb AP, cha chinggggg!! Thanks again for everyone's help! Respectfully, Mac Link to comment Share on other sites More sharing options...
Adoniram Posted March 22, 2012 Share Posted March 22, 2012 There are new instructions for making it all work with Win 7 in the "complete beginners guide" thread. I just posted those last week and tested on Home Premium and Enterprise. Both worked the same, and it's easier than XP. Link to comment Share on other sites More sharing options...
2manysubies Posted March 23, 2012 Author Share Posted March 23, 2012 Well I tried this all morning to get Win 7 to find a driver, which it did, kind of generic, usb{}-serial, was listed at the bottom of ecuflash, no, didn't work on the car either, I even took apart the cable OBDII end, 4 screws, to admire the cold and incomplete solder joints on the circuit board(which I fixed). I really wanna get the .50 cal out and "Fix" it for good, the only driver this cable is gonna get is me driving over it with the car! time for another choice. I'm pondering.. Link to comment Share on other sites More sharing options...
bmx045 Posted March 23, 2012 Share Posted March 23, 2012 Solution: http://www.tactrix.com Link to comment Share on other sites More sharing options...
