xt2005bonbon Posted March 16, 2012 Share Posted March 16, 2012 I unbolted my OEM intercooler the other day (for the first time) and noticed a thin film of oil inside from each end. I got scared cause I first thought it was supposed to be dry in there. From my own research, I now understand that it is blowby and that we should have some and it is normal. But how much is too much in the intercooler? Link to comment Share on other sites More sharing options...
Strizzy Posted March 16, 2012 Share Posted March 16, 2012 Too much is when you are low on oil between changes. How often do you check your oil? My bad luck build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 16, 2012 Author Share Posted March 16, 2012 twice between every fill up. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 19, 2012 Author Share Posted March 19, 2012 bump for more feedback . Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 19, 2012 Share Posted March 19, 2012 Ever change the PCV? Made a big difference for me when I swapped out my clogged up old one. Link to comment Share on other sites More sharing options...
FJuan Posted March 19, 2012 Share Posted March 19, 2012 http://legacygt.com/forums/attachment.php?attachmentid=114450&d=1332194033 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 19, 2012 Author Share Posted March 19, 2012 Ever change the PCV? Made a big difference for me when I swapped out my clogged up old one. No I have not changed the PCV yet. I may have to do it. I had the same concerns last year when I saw a good amount of oil in my I/C and intake tube. Decided to use a catch can to catch the oil coming up from the valve covers, and in 3 months this is how much oil I've caught from blow by. Ever since then, my I/C and intake tube has been clean. wow. interesting..How did you install this catch can? And what do you mean by the intercooler was 'clean'? Was it perfectly dry inside or was there still a thin oil coat? Link to comment Share on other sites More sharing options...
FJuan Posted March 19, 2012 Share Posted March 19, 2012 I did a full walkthrough over on .org. - http://www.legacygt.org/forums/showthread.php?t=2408 For the most part, it has stayed clean. Plus, before I did the catch can I replaced the PCV valve and hoses. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2012 Author Share Posted March 20, 2012 k thank you. I'll check out your thread for sure. As for your definition of clean, I will assume you mean the inside of the I/C was completely dry and you did not have an oil film in there. Link to comment Share on other sites More sharing options...
bmx045 Posted March 20, 2012 Share Posted March 20, 2012 It befondles me how both you guys with a vf40 are getting that much blow-by Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2012 Author Share Posted March 20, 2012 It befondles me how both you guys with a vf40 are getting that much blow-by Are you saying that one should expect to have their stock intercooler almost dry inside if one would do a random check on it? (with stock everything) Link to comment Share on other sites More sharing options...
bmx045 Posted March 20, 2012 Share Posted March 20, 2012 not dry, a little film of oil.... but that's it. If I were you I'd replace the pcv first, it's like a $20 part at the dealer. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2012 Author Share Posted March 20, 2012 not dry, a little film of oil.... but that's it. If I were you I'd replace the pcv first, it's like a $20 part at the dealer. ok. that's what I got. But I will still go ahead and change it. Problem is I currently am on the other side of the pond..will have to pay extra for shipping.. On another note, interesting to see that the official subaru inspection sheet does not include checking or replacing this part. Link to comment Share on other sites More sharing options...
bmx045 Posted March 20, 2012 Share Posted March 20, 2012 no, they usually just replace it when a code pops. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2012 Author Share Posted March 20, 2012 no, they usually just replace it when a code pops. ^^that's correct. thanks everyone for your input. I think it is now pretty clear how much blow-by is OK in the I/C. Link to comment Share on other sites More sharing options...
FJuan Posted March 20, 2012 Share Posted March 20, 2012 k thank you. I'll check out your thread for sure. As for your definition of clean, I will assume you mean the inside of the I/C was completely dry and you did not have an oil film in there. Clean as in clean. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2012 Author Share Posted March 20, 2012 Clean as in clean. I actually wonder if you get a slight boost in performance when the I/C is perfectly dry vs. the one with the regular 'thin' oil coat. Link to comment Share on other sites More sharing options...
FJuan Posted March 20, 2012 Share Posted March 20, 2012 My butt dyno couldn't tell the difference, so I have to say there wasn't enough oil being sucked in to make that difference. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
bmx045 Posted March 20, 2012 Share Posted March 20, 2012 if you feel and notice a difference in how the car runs after installing a catch can or AOS, you've got much bigger problems to deal with. Link to comment Share on other sites More sharing options...
mwm5094 Posted March 20, 2012 Share Posted March 20, 2012 I bought a CC for piece of mind. After ~5 months Im seeing drops. Thats it. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 20, 2012 Share Posted March 20, 2012 It befondles me how both you guys with a vf40 are getting that much blow-by Pcv. Believe it or not my oem IC was pretty full of oil and so were my RacerX pipes until swapping out the pcv (vf40). Suprised me too. Link to comment Share on other sites More sharing options...
bmx045 Posted March 20, 2012 Share Posted March 20, 2012 it just fondles me Link to comment Share on other sites More sharing options...
FJuan Posted March 20, 2012 Share Posted March 20, 2012 I'm sure you fondle yourself. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 20, 2012 Moderators Share Posted March 20, 2012 I bought a CC for piece of mind. After ~5 months Im seeing drops. Thats it. Aren't you installing a VB mod today? Back to work! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
WhiskeyTango Posted March 20, 2012 Share Posted March 20, 2012 twice between every fill up. wow...paranoid much? I did a full walkthrough over on .org. - http://www.legacygt.org/forums/showthread.php?t=2408 For the most part, it has stayed clean. Plus, before I did the catch can I replaced the PCV valve and hoses. Is .ORG still around? Anyone have the link to Freedbeen PVC replacement with the hoses and everything? Link to comment Share on other sites More sharing options...
