dustdown Posted March 14, 2012 Share Posted March 14, 2012 I've looked at a bunch of threads but I'm sick of searching for them. Just wanna hear some advice and experience on how someone resolved a missfire on a cylinder. I don't have the car but I'm on the fence of buying it pending the cost of repair. Any input? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 14, 2012 Share Posted March 14, 2012 When were the plugs changed last ? Have you done a web search for that problem ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DocHolladay23 Posted March 14, 2012 Share Posted March 14, 2012 It will likely cost between $0 and $6,000. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
landark Posted March 15, 2012 Share Posted March 15, 2012 Plenty of input on that car, actually: http://legacygt.com/forums/showthread.php/anyones-cari-181583.html My advice is to not spend $12k on a modified car with major issues the dealer doesn't want to try to fix. Link to comment Share on other sites More sharing options...
dustdown Posted March 16, 2012 Author Share Posted March 16, 2012 ^thanks man I'm actually love that thread right now cause everyone is saying exactly what I was thinking Link to comment Share on other sites More sharing options...
mwm5094 Posted March 16, 2012 Share Posted March 16, 2012 That car will be nothing but a headache. Not worth your time. You will need your black nike's for all the times it will need fixed. Link to comment Share on other sites More sharing options...
dustdown Posted March 16, 2012 Author Share Posted March 16, 2012 Lol Link to comment Share on other sites More sharing options...
dustdown Posted April 13, 2012 Author Share Posted April 13, 2012 Ok I'm just adding to my thread a new problem for the sake of starting a new thread elsewhere. I had a misfire in cylinder 2 and 3... Took it to a friends shop and they replaced the faulty coil packs on cyl 2 and 3 and replaced all 4 plugs. Get it back and the car runs fine for 3-4 days and then starts running funny and when i accelerate up a hill or something it would sound like somethings grinding and the CEL came back on as well as my blinking cruise control but I know thats a failsafe or something so you dont use it. Two nights ago I go out to get drunk and the car breaks down on me and wont start. Basically I got home by flooring the gas and the car could only go about 4 miles an hour. The day before this I went to auto zone and ran codes and came up with the following: MAF air flow circuit low input Intake air temp circuit high input Camshaft position A - timing over advance or performance Bank 1 Camshaft position A - timing over advance or performance Bank 2 Yesterday I changed my oil, started it up and my car was pushing tons of white smoke out the tail pipes. I'm lost. Who can help me please?? Link to comment Share on other sites More sharing options...
No DRFT Posted April 13, 2012 Share Posted April 13, 2012 Hm...I would rule out the possible problematic areas. Check/clean the MAF sensor and intake components. Possible air leaks? Not sure about the camshaft one. And you should've gotten a ride home or called a tow truck. Given what you did, you may caused more problems then it did. I have no control over drippie. Link to comment Share on other sites More sharing options...
Leviman Posted April 14, 2012 Share Posted April 14, 2012 When was the last time the timing belt was changed? It could be that it skipped a tooth. To me it sounds like something is really seriously screwed up. Could also be head gasket? That would cause white smoke. Does the smoke smell sweet? Link to comment Share on other sites More sharing options...
m sprank Posted April 14, 2012 Share Posted April 14, 2012 Is it an automatic? Link to comment Share on other sites More sharing options...
dustdown Posted April 15, 2012 Author Share Posted April 15, 2012 When was the last time the timing belt was changed? It could be that it skipped a tooth. To me it sounds like something is really seriously screwed up. Could also be head gasket? That would cause white smoke. Does the smoke smell sweet? I have no idea when the timing belt was changed last i just got this car about 4000 miles ago and I'm thinking that it is a head gasket but I dont think the smoke smells sweet Link to comment Share on other sites More sharing options...
dustdown Posted April 15, 2012 Author Share Posted April 15, 2012 Is it an automatic? yes it is Link to comment Share on other sites More sharing options...
m sprank Posted April 15, 2012 Share Posted April 15, 2012 Being that it is an AT, there is no answer on the forums. Far too many electrical issues that can result with a 5EAT. Some can cause exactly what you are describing. Link to comment Share on other sites More sharing options...
