Moderators BarManBean Posted March 2, 2012 Moderators Share Posted March 2, 2012 Logged a 3rd gear pull for the first time today. Hopefully I have the right parameters in there. Any input would be appreciated. Right now I'm just looking for an overall healthy report so I can go stage 2. All of my logging stuff seems to be working well now romraiderlog_20120302_130623.csv "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 2, 2012 Mega Users Share Posted March 2, 2012 You want to use manifold relative pressure 4byte instead of the one you used, and knock sum. You can also use feedback and fine learning knock correction if you want. You can get rid of maf, knock correction advance, and the a/f learning pids. But they shouldn't slow down the logging much with the fast polling option. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 3, 2012 Author Moderators Share Posted March 3, 2012 Thanks. I changed the manifold pressure and got rid of MAF, Knock Correction Advace, and A/F learning for next time. I don't see either "knock sum" or "fine learning knock correction"... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 3, 2012 Mega Users Share Posted March 3, 2012 They only show up after you connect to the car. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 3, 2012 Author Moderators Share Posted March 3, 2012 They only show up after you connect to the car. Tricky, tricky...I'll take a look next time. Thanks for the help! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
iNVAR Posted March 3, 2012 Share Posted March 3, 2012 You need to add IAM (4-byte) in. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 3, 2012 Author Moderators Share Posted March 3, 2012 You need to add IAM (4-byte) in. Roger. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
