maddoc Posted May 21, 2012 Author Share Posted May 21, 2012 Will do and report back. Link to comment Share on other sites More sharing options...
1055 Posted May 22, 2012 Share Posted May 22, 2012 I thought my wagon was fine with 255's.... till i tried to pull it off of ny lift lol Link to comment Share on other sites More sharing options...
maddoc Posted May 22, 2012 Author Share Posted May 22, 2012 What were the wheel specs and suspension specs? Link to comment Share on other sites More sharing options...
1055 Posted May 23, 2012 Share Posted May 23, 2012 17x9.5 +19 vette sawblades. 255/40/17 yokohoma s drives. Omnipower coilovers. I had to shave down the lock collar on the coil 3/16th of an inch and hammer out the rear wheel well a bit. Car was also lowered 5.5" front, 5" rear Link to comment Share on other sites More sharing options...
maddoc Posted May 30, 2012 Author Share Posted May 30, 2012 I have well over an inch of inboard clearance, possibly even 2 inches. Trying to get pics. I went to pull the car out of the garage after getting all the wheels on the other day and as I finished up the last wheel we got a torrential down pour. Link to comment Share on other sites More sharing options...
maddoc Posted June 1, 2012 Author Share Posted June 1, 2012 Left side of the car jacked up... This is the right side showing the rear wheel into the arch: http://i102.photobucket.com/albums/m119/kmaddock/PrjktB/255s/IMG_0240Medium.jpg Front Left: http://i102.photobucket.com/albums/m119/kmaddock/PrjktB/255s/IMG_0242Medium.jpg Side: http://i102.photobucket.com/albums/m119/kmaddock/PrjktB/255s/IMG_0241Medium.jpg Back: http://i102.photobucket.com/albums/m119/kmaddock/PrjktB/255s/IMG_0245Medium.jpg http://i102.photobucket.com/albums/m119/kmaddock/PrjktB/255s/IMG_0246Medium.jpg Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2012 Share Posted June 1, 2012 you're not hitting the tires at all (didnt see the tell-tale cut)? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
maddoc Posted June 1, 2012 Author Share Posted June 1, 2012 The car has only moved about 10 feet since I put the wheels on, but ywah, the rear tires are probably going to rub. Fender rolling on the rear is in the near future. Link to comment Share on other sites More sharing options...
lil_z_33 Posted June 6, 2012 Share Posted June 6, 2012 maddoc...car looks great... how much space do you have between the wheels/tires and the suspension? also, what suspension are you running? Link to comment Share on other sites More sharing options...
maddoc Posted June 6, 2012 Author Share Posted June 6, 2012 Close to 2" of inner clearance on both front and rear. I am running BC Racing coilovers. Link to comment Share on other sites More sharing options...
lil_z_33 Posted June 7, 2012 Share Posted June 7, 2012 awesome...thanks for your input...that makes me believe that I can run 18x8.5 +48 offset with 255/35/18... Link to comment Share on other sites More sharing options...
mk6933 Posted June 19, 2012 Share Posted June 19, 2012 What rims are they? Link to comment Share on other sites More sharing options...
Imprezsing04 Posted June 22, 2012 Share Posted June 22, 2012 looking good. what are they? And you have a 06 wrx?? oh how far we have come... Link to comment Share on other sites More sharing options...
maddoc Posted June 22, 2012 Author Share Posted June 22, 2012 Basically they're Wedsport SA55M "knock-offs". They're Advanti Racing Vago V3s. I don't know how many sets are available, I know they were rare to find in an 18x9 +43. And yeah - 06 WRX wagon. Bought it a few weeks ago for daily duty. Link to comment Share on other sites More sharing options...
mk6933 Posted June 23, 2012 Share Posted June 23, 2012 Hmm... Interesting. How much did you pay? I might be interested in a set. It doesn't seem like it poke a lot? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted June 30, 2012 Share Posted June 30, 2012 I just put 255/40/18s +35 offset on my outback today but I have the cheater fender flares. Thanks for posting those pics of your 255s because it made me pull the trigger on mine. Link to comment Share on other sites More sharing options...
maddoc Posted July 4, 2012 Author Share Posted July 4, 2012 Glad I could help, but yeah your Outback definitely has a couple more inches in outboard clearance - cheater ! Link to comment Share on other sites More sharing options...
OutbackXT05 Posted July 4, 2012 Share Posted July 4, 2012 Ya I know and I used it all. Slightly tucking in the front and the rears tuck in nicely with weight in the trunk. Link to comment Share on other sites More sharing options...
maddoc Posted July 19, 2012 Author Share Posted July 19, 2012 So I'm running into a few issues. Either the car is too low, or I didn't roll enough. I drove the car about 3 miles today (total) and when I got home I found that the painted plastic piece that is right below the rear door was unclipped. I guess I was rubbing on it? Not sure if I need to add more negative camber, cut the plastic and roll that area? Hmph. Might have to talk to the Hellaflush kiddies. Link to comment Share on other sites More sharing options...
lil_z_33 Posted July 19, 2012 Share Posted July 19, 2012 So I'm running into a few issues. Either the car is too low, or I didn't roll enough. I drove the car about 3 miles today (total) and when I got home I found that the painted plastic piece that is right below the rear door was unclipped. I guess I was rubbing on it? Not sure if I need to add more negative camber, cut the plastic and roll that area? Hmph. Might have to talk to the Hellaflush kiddies. I had that issue with 19x8 +34 offset while running 235/35/19...raised the suspension a little and the problem got solved. Link to comment Share on other sites More sharing options...
maddoc Posted July 19, 2012 Author Share Posted July 19, 2012 The rear is sitting a little low right now, less than a finger gap in the rear, so raising it may help. Link to comment Share on other sites More sharing options...
subiegillis Posted September 26, 2012 Share Posted September 26, 2012 The rear is sitting a little low right now, less than a finger gap in the rear, so raising it may help. so i have a question don't mean to thread jack but do you think if you went with a higher offset you could have gone without rolling the fenders ?or rolled them and dropped it lower? Link to comment Share on other sites More sharing options...
Drift Motion Posted September 26, 2012 Share Posted September 26, 2012 you'll have to roll the fenders for 255s my 255s almost fit on my 9 +38 wheel just my coils are too low, either right ride height, or a camber adjustment or a pull would fix it Link to comment Share on other sites More sharing options...
boxkita Posted September 27, 2012 Share Posted September 27, 2012 @SubieGillis - goto your local tire store, dig thru their pile of tires for a 255 (ask first), pull a wheel off your car, stuff the 255 in the wheel well (unmounted). If you drop the jack down slowly, you can see how the tire would fit. Nothing like seeing it for yourself. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
maddoc Posted September 27, 2012 Author Share Posted September 27, 2012 so i have a question don't mean to thread jack but do you think if you went with a higher offset you could have gone without rolling the fenders ?or rolled them and dropped it lower? A higher offset and you start to run the risk of hitting the strut/coilover. Though if you're running a 255, you more than likely need coilovers. I have no idea how you'd fit a 9" wheel with 255s under the car without coilovers... Link to comment Share on other sites More sharing options...
