Merc6 Posted December 10, 2015 Share Posted December 10, 2015 The only time I have seen my temp gauge spike and the ErHc code come up is when I am flashing the ECU. Were you messing with the ECU before this happened? http://i90.photobucket.com/albums/k280/merc6/LGT/2E0E27FE-012A-48B5-8CA2-5A139D507603_zpsi6fskbtw.jpg~original Big connection spoke of removed with engine pull. trip button presed resets the er hc for a few seconds. When battery dropped to 50% from listening to the radio & subs, the erhc would leave and the coolant needle would fall. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
subi_life Posted December 10, 2015 Share Posted December 10, 2015 The only time I have seen my temp gauge spike and the ErHc code come up is when I am flashing the ECU. Were you messing with the ECU before this happened? No I wasn't, I got a car wash and drove about 3 miles to the dmv left there and drove straight home the car just turned off as soon as I got on my street.. Link to comment Share on other sites More sharing options...
subi_life Posted December 10, 2015 Share Posted December 10, 2015 Did you check the large wire harness under the hood by the passenger firewall area? Or the green connectors in the pass. foot well, under the carpet ? What where you doing before it did this ? How do I get to those green connectors? Are you talking about the one green connector under the passenger dash?? Link to comment Share on other sites More sharing options...
subi_life Posted December 10, 2015 Share Posted December 10, 2015 How are your chassis grounds? There are 2 underneath and 2 more on a bracket on the back of the driver side tgv housing. Those can cause this err hc sypmtom. Other things to check as mentioned in the post is the wiring harness connector by the passenger shock, and all battery connections/leads Can you tell me where all the grounds are so I can check them please Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted December 11, 2015 Share Posted December 11, 2015 Sorry I didn't see this sooner. Under the engine on each side of the heads there should be one. Then there's metal bracket attached to the tgvs. It's in the drivers corner of the engine bay below the BPV. If these get corroded it could be bad news. I had err hc for 2 days after a rebuild cuz one was loose and I didn't think to check there. The 2 pics are of the bracket. One is just farther out for reference. Link to comment Share on other sites More sharing options...
subi_life Posted December 12, 2015 Share Posted December 12, 2015 Could that cause my car not to start? It dosent even turn over... And the coolint temp is all the way to hot and I haven't drove it for two days Link to comment Share on other sites More sharing options...
subi_life Posted December 13, 2015 Share Posted December 13, 2015 Was the corrosion keeping a ground from not working? My cars at the dealership now. But I can call them and let them know another possible problem Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted December 13, 2015 Share Posted December 13, 2015 I know the ground that I pictured will cause a no-crank no-start condition if it's failing for any reason. ERR HC means the ecu is not communicating with the engine sensors. It can be a battery/grounding issue, something with the main harness, or in the worst cases a bricked ecu. I sincerely hope it's not the latter. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 13, 2015 Share Posted December 13, 2015 Bricked ECM. Send it to Cobb and for $75.00 they will unbrick it and return it quickly for you. Link to comment Share on other sites More sharing options...
Merc6 Posted December 13, 2015 Share Posted December 13, 2015 Bricked ECM. Send it to Cobb and for $75.00 they will unbrick it and return it quickly for you. I wish it was that easy when I bricked mine years ago. $1000 each time. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
subi_life Posted December 13, 2015 Share Posted December 13, 2015 Dealership said they found the problem it was a electrical problem. But need 2 more hours to pinpoint... Gunna cost me 500 just for diognostics .. Oh well I guess aslong as its fixed... Link to comment Share on other sites More sharing options...
subi_life Posted December 14, 2015 Share Posted December 14, 2015 What dose bricked mean? Link to comment Share on other sites More sharing options...
Merc6 Posted December 14, 2015 Share Posted December 14, 2015 What dose bricked mean? Fried. Not the chicken kind. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
StkmltS Posted December 14, 2015 Share Posted December 14, 2015 I've seen the ER HC error several times, most recently last night. Each time it ended up being just a loose/dirty connection at the negative terminal on the battery. Sent from inner space. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
subi_life Posted December 15, 2015 Share Posted December 15, 2015 Yeah I replaced the connections for the battery still nothing. The dealership said it was a bad wire.. As they say... Link to comment Share on other sites More sharing options...
subi_life Posted December 27, 2015 Share Posted December 27, 2015 It was a blown fuse on my car I got it fixed ran good for 3 days and now it's running rough at idle and misfiring Link to comment Share on other sites More sharing options...
StkmltS Posted December 30, 2015 Share Posted December 30, 2015 Bricked ECM. Send it to Cobb and for $75.00 they will unbrick it and return it quickly for you. Do you know if they'll do this even if a Cobb product (AP) has never been used on the ECU? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
silentsnow31802 Posted December 31, 2015 Share Posted December 31, 2015 It was a blown fuse on my car I got it fixed ran good for 3 days and now it's running rough at idle and misfiring Are you telling me you paid $500+ dollars for them to find and replace a blown fuse? Link to comment Share on other sites More sharing options...
subi_life Posted December 31, 2015 Share Posted December 31, 2015 Are you telling me you paid $500+ dollars for them to find and replace a blown fuse? Yup... That's bullshit huh! That's why I'm doing the work myself now. Same thing is happening again but I'm not gunna take it to them because I'm sure I can find the problem my self. I just thought these type of cars need professional work done but really it's just the same as my 97 legacy gt. I have another thread in my problem now :/ it's called knocking and shaking. Happend 2 days after I got it from them Link to comment Share on other sites More sharing options...
StkmltS Posted January 1, 2016 Share Posted January 1, 2016 Yup... That's bullshit huh! That's why I'm doing the work myself now. Same thing is happening again but I'm not gunna take it to them because I'm sure I can find the problem my self. I just thought these type of cars need professional work done but really it's just the same as my 97 legacy gt. I have another thread in my problem now :/ it's called knocking and shaking. Happend 2 days after I got it from them Do you know which fuse blew? My car's dead (again) because of the ER HC code. Have you checked for vacuum/boost leaks? If your idle is really funky it could just be a big leak somewhere. Your motor may not be knocking, the sensor could just be reporting false knocks from your car lurching and jerking (if it's that bad). If you need ideas on things to try check out my misfire thread in my signature. My root problem ended up being a cracked piston, but I've tried many things to try to fix my rough idle/misfire. Do you have a way to log/tune? If you have an Android device I highly recommend getting BtSSm. It's awesome for logging and monitoring everything going on with your motor. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Anthony I Posted December 1, 2017 Share Posted December 1, 2017 Ran into this same issue.Throws code ER HC on dash.Wont turn over and temp goes into red.What could be the issue Link to comment Share on other sites More sharing options...
StkmltS Posted December 4, 2017 Share Posted December 4, 2017 Check for a loose ground somewhere. The main one near the starter was the problem for me. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
utc_pyro Posted December 5, 2017 Share Posted December 5, 2017 A short in the 5V accessor bus will also cause this. Just found that out tonight when testing a sensor! Link to comment Share on other sites More sharing options...
Anthony I Posted December 5, 2017 Share Posted December 5, 2017 I noticed also if it helps a few days b4 my battery was just killing itself and wouldn’t hold charge.I will check the grounds tommorow on my lunch break as my car is stored at my job and fingers cross u can get it started.Thanks for the help! Link to comment Share on other sites More sharing options...
