ehsnils Posted February 13, 2012 Share Posted February 13, 2012 Please post your tricks and tweaks that you have for your fifth gen here. Link to comment Share on other sites More sharing options...
ehsnils Posted February 13, 2012 Author Share Posted February 13, 2012 You need to adjust the computer: Go fast...ignition on turn headlights on hit trip meter 5 times headlights off hit trip meter 5 times headlights on hit trip meter 5 times Now you can adjust the MPG reading on the first option screen. Default is zero I set mine to -2 and its much closer. Link to comment Share on other sites More sharing options...
LoHud 3.6R Posted February 13, 2012 Share Posted February 13, 2012 How do turn off that annoying seatbelt chime?! You have 30 seconds from when u turn the car on, click in the seatbelt and remove 20 times. I know it sounds like BS but it worked for me... I always wear my seatbelt, i dont need a reminder. Link to comment Share on other sites More sharing options...
Patrickturner Posted February 13, 2012 Share Posted February 13, 2012 This is not really a trick just a tid-bit: the owners folder (holds all the books) fits perfectly in the rear door pockets. THis cleans up the glove box for other crap like extra napkins and straws Link to comment Share on other sites More sharing options...
acumenhokie Posted February 14, 2012 Share Posted February 14, 2012 How do turn off that annoying seatbelt chime?! You have 30 seconds from when u turn the car on, click in the seatbelt and remove 20 times. I know it sounds like BS but it worked for me... I always wear my seatbelt, i dont need a reminder. http://legacygt.com/forums/showthread.php/2010-lgt-seatbelt-chime-disable-124894.html?t=124894 It can also be done with the Subaru Select Tool. Link to comment Share on other sites More sharing options...
Patrickturner Posted February 14, 2012 Share Posted February 14, 2012 http://legacygt.com/forums/showthread.php/2010-lgt-seatbelt-chime-disable-124894.html?t=124894 It can also be done with the Subaru Select Tool. Whats the Subaru Select Tool? Link to comment Share on other sites More sharing options...
SurlyOldManMN Posted February 14, 2012 Share Posted February 14, 2012 The proprietary computer doo-hicky that only subaru dealerships have. Link to comment Share on other sites More sharing options...
Patrickturner Posted February 14, 2012 Share Posted February 14, 2012 The proprietary computer doo-hicky that only subaru dealerships have. Ahhh the Thousand some odd dollar gameboy Thanks lol Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted February 14, 2012 Share Posted February 14, 2012 i just spent half an hour trying to turn the chime off with no luck. do i turn the key to acc or to on? i insert and take out the seatbelt 20 times that turn the key to the off position and then start the car. what am i doing wrong? Link to comment Share on other sites More sharing options...
stu1811 Posted February 14, 2012 Share Posted February 14, 2012 On, but not running. Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted February 15, 2012 Share Posted February 15, 2012 Figured it out. I wasnt going fast enough. Now i got to figure out how to turn off the beep when i lock and unlock my car Link to comment Share on other sites More sharing options...
Gary245 Posted February 15, 2012 Share Posted February 15, 2012 SEATBELT CHIME ELIMINATION 1. Insert key into ignition. Turn to "Accessory On" position. This is the last click before you would turn the key to start the engine. Your radio and annoying seatbelt chime will be ON. 2. Within 5 seconds of turning your key to "ACC ON", take your seatbelt clip, and INSERT & RELEASE into the buckle 20 times repeatedly. Each time you INSERT the clip into the buckle, it must "click" into place. You must push the release button to remove it. Complete this 20 times within 30 seconds. 3. When you have completed the 20 clicks, turn your key off and remove it from the ignition. 4. Start your car as normal. You will notice that the seatbelt indicator chime will sound six (6) times, then go off. It will NOT come back on until the next time you start your car, and it will stay on this pattern indefinately. 5. To re-active your annoying seatbelt chime, simply unhook your positive (+) battery terminal for 30 seconds to reset the ECU. Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted February 15, 2012 Share Posted February 15, 2012 how do i turn off the beep when locking and unlocking the car? i tried what was in the owners manual and wasnt able to get it to work but had no luck. Link to comment Share on other sites More sharing options...
faded-a-fool Posted February 15, 2012 Share Posted February 15, 2012 how do i turn off the beep when locking and unlocking the car? i tried what was in the owners manual and wasnt able to get it to work but had no luck. Try it again carefully. I can confirm the method in the manual works. Link to comment Share on other sites More sharing options...
nstg8r Posted February 15, 2012 Share Posted February 15, 2012 Try it again carefully. I can confirm the method in the manual works. Worked for me, too. Link to comment Share on other sites More sharing options...
ehsnils Posted February 17, 2012 Author Share Posted February 17, 2012 Disabling safety features on the nav system http://legacygt.com/forums/showpost.php?p=2681828&postcount=48 Link to comment Share on other sites More sharing options...
cc149 Posted February 17, 2012 Share Posted February 17, 2012 How do turn off that annoying seatbelt chime?! You have 30 seconds from when u turn the car on, click in the seatbelt and remove 20 times. I know it sounds like BS but it worked for me... I always wear my seatbelt, i dont need a reminder. I just unplugged mine under the rear of the seat, it is the only plug with two wires. Jim Link to comment Share on other sites More sharing options...
Slider Posted February 19, 2012 Share Posted February 19, 2012 Disabling safety features on the nav system http://legacygt.com/forums/showpost.php?p=2681828&postcount=48 Just need to figure out how to get rid of the "accept" button on the nav every time you start the car Link to comment Share on other sites More sharing options...
NinjaLGT Posted February 21, 2012 Share Posted February 21, 2012 This is not really a trick just a tid-bit: the owners folder (holds all the books) fits perfectly in the rear door pockets. THis cleans up the glove box for other crap like extra napkins and straws If you do this, remember to take out the metal tag with security numbers etched in it needed to cut replacement keys for your car... you wouldn't want the vallet guy or anyone else getting their hands on that! This was the only reason I left my folder at home (because I like to keep all my documents together). Link to comment Share on other sites More sharing options...
Patrickturner Posted February 21, 2012 Share Posted February 21, 2012 If you do this, remember to take out the metal tag with security numbers etched in it needed to cut replacement keys for your car... you wouldn't want the vallet guy or anyone else getting their hands on that! This was the only reason I left my folder at home (because I like to keep all my documents together). Good Idea, though interesting.... My Key ID came on my keyring and not in the folder. I keep mine with the spare key in the closet at home (shhh....) I always like to have the book close by just in case.... Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted February 21, 2012 Share Posted February 21, 2012 i have a folder at home that has all of my papers and service records along with the tags taped inside the folder and also have it written down also. Link to comment Share on other sites More sharing options...
mosthated Posted February 21, 2012 Share Posted February 21, 2012 same here Link to comment Share on other sites More sharing options...
Patrickturner Posted February 21, 2012 Share Posted February 21, 2012 i have a folder at home that has all of my papers and service records along with the tags taped inside the folder and also have it written down also. Since I have a lot of car write-offs, I need to keep great records. I use the neat desk scanner... that thing is amazing, and I dont have to have the papers laying around. They can be a heck of a pile after a while. Link to comment Share on other sites More sharing options...
CHUCKmfnNORRIS Posted February 21, 2012 Share Posted February 21, 2012 ^what happens when your computer crashes or gets a virus? Link to comment Share on other sites More sharing options...
SurlyOldManMN Posted February 21, 2012 Share Posted February 21, 2012 ^what happens when your computer crashes or gets a virus? What happens when your filing cabinet starts on fire? Link to comment Share on other sites More sharing options...
