Dragoeth Posted February 8, 2012 Share Posted February 8, 2012 So 4k miles and 3 months ago my tob pretty much disintegrated. Took it to the stealership I had recently bought it from and paid 1800 to have it replaced along with the clutch and flywheel (since they were still working but had 120,000 miles on them and were pretty worn). Dealership told me 1 year warranty on all work. Now I can hear the same noise from right before my TOB blew and my clutch pedal is getting a little rough feel to it. So I'm 99% positive its about to die again. I'm bringing it in to have them check it out and pull the warranty on them but I'm just wondering how it went out after only 4k miles. Is there even a way to wear one down that fast or is it possible the mechanic didn't install it properly (maybe didn't grease it)? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 8, 2012 Mega Users Share Posted February 8, 2012 Could be other damage that was missed. I had a catastrophic TB failure on a different car and it bent the clutch fork. That was missed and it caused a failure of the replacement tb, which destroyed the replacement clutch and pressure plate in about 2k miles. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 8, 2012 Share Posted February 8, 2012 Have them install the TSK3 kit for the better set up of the TOB. http://www.google.com/#hl=en&cp=4&gs_id=d&xhr=t&q=tsk3&pf=p&sclient=psy-ab&site=&source=hp&pbx=1&oq=tsk3&aq=0&aqi=g4&aql=&gs_sm=&gs_upl=&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=c564f89143e67f09&biw=1011&bih=592 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Dragoeth Posted February 8, 2012 Author Share Posted February 8, 2012 Unfortunately if I go with warranty for the work they won't cover putting in a TSK3 otherwise I would do it. Could probably argue them to put it in for free if I bought myself however since the one they put in is screwed up anyways. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 8, 2012 Share Posted February 8, 2012 it might be worth a shot to see if they would install it, and credit the cost of the oem one that failed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
