br7sv9x8 Posted June 28, 2005 Share Posted June 28, 2005 what rotor will fit the legacy will the STI fit or will the legacy 2004 still fit the 2005? which one will fit please tell thank you. Link to comment Share on other sites More sharing options...
apexjapan Posted June 28, 2005 Share Posted June 28, 2005 STi will not fit unless you use a big brake kit of some sort. The 2004, well, since there is no small brake kits, I don't think that would work. The Legacy GT uses a 315mm rotor, which is relatively new in the Subaru world. DBA makes rotors for the Legacy GT, along with Project Mu and a few others. Cheers, Paul Hansen http://www.avoturboworld.com http://www.sevenphotos.com http://www.apexjapan.com Link to comment Share on other sites More sharing options...
br7sv9x8 Posted June 28, 2005 Author Share Posted June 28, 2005 so that means there are none that will fit it then. so i cant get cross drill rotor upgrade for the LGT 05'? Link to comment Share on other sites More sharing options...
wukindada Posted June 28, 2005 Share Posted June 28, 2005 Don't believe so... If you do find any let me Know! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
praedet Posted June 28, 2005 Share Posted June 28, 2005 Search, there are two vendors on this forum that have slotted and/or cross-drilled rotors... Link to comment Share on other sites More sharing options...
br7sv9x8 Posted June 28, 2005 Author Share Posted June 28, 2005 oo but im getting my customs so i just want to know will they fit tho on the stock break pads and the stock break system with out upgrading it to the big break system.my friend and i are getting custom rotor and i just want to see when one will fit on the legacy if none then i guess i will be the first to find out if they fit. thanks- Link to comment Share on other sites More sharing options...
melayout Posted June 28, 2005 Share Posted June 28, 2005 If you are going to change rotors, use different pads. The stock OEM pads are not up to par. Many including me, have experienced brake shake because of uneven pad deposits(aka rotor warpage). Check out: http://www.legacygt.com/forums/showthread.php?t=8911&highlight=brake+shake http://www.legacygt.com/forums/showthread.php?t=13499&highlight=brake+shake http://www.legacygt.com/forums/showthread.php?t=13872&highlight=brake+shake http://www.legacygt.com/forums/showthread.php?t=9009&highlight=brake+shake Mojo I keed I keeed Link to comment Share on other sites More sharing options...
br7sv9x8 Posted June 28, 2005 Author Share Posted June 28, 2005 thank you for telling me ahead of time. Link to comment Share on other sites More sharing options...
miles Posted June 28, 2005 Share Posted June 28, 2005 what rotor will fit the legacy will the STI fit or will the legacy 2004 still fit the 2005? which one will fit please tell thank you. Ask your question in the Suspension/Brakes forum: http://www.legacygt.com/forums/forumdisplay.php?f=20 Link to comment Share on other sites More sharing options...
Xenonk Posted June 28, 2005 Share Posted June 28, 2005 moved to brakes section Keefe Keefe Link to comment Share on other sites More sharing options...
iON Performance Posted June 29, 2005 Share Posted June 29, 2005 br7sv9x8 - Drop us a line, we make 2-piece direct replacement rotors for the '05-up LGT which are ~6-7lbs lighter then stock. They're available in x-drilled or slotted. Link to comment Share on other sites More sharing options...
br7sv9x8 Posted June 29, 2005 Author Share Posted June 29, 2005 how much is it to make it for mine all 4 rotors cross drill and slotted? Link to comment Share on other sites More sharing options...
iON Performance Posted June 29, 2005 Share Posted June 29, 2005 br7sv9x8 - Our 2-piece/multi-piece replacement rotors come with either plain, x-drilled or slotted discs. We do not recommend x-drilling & slotting as it would defeat the purpose of either and reduce pad contact area significantly. Check your PM's for more info. Link to comment Share on other sites More sharing options...
