chucktoo Posted June 27, 2005 Share Posted June 27, 2005 I am looking for some heavy duty wheel studs to go with my Gorrilla 5x100 wheel spacers ? To keep my SSR comps keep rubbing my struts and sway bars. I have seen mention of 60mm long Nismo studs are they much heavier duty ? Are there some others out there I just have not found ? Thanks in advance for any help. Charlie Link to comment Share on other sites More sharing options...
rao Posted June 27, 2005 Share Posted June 27, 2005 http://www.moserengineering.com/moser_interior/products.asp?CatID=17 http://www.arp-bolts.com/media/pdf_files/DR_48-52.pdf I'd get the ARPs Getting serious, huh? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
chucktoo Posted June 27, 2005 Author Share Posted June 27, 2005 Thanks for the leads but I think the knurls are wrong ? I think our studs are: Knurl-------.563 Diam Length-----41.5 MM Sholder-----14.5 MM Thread------m12 x 1.25 If anyone has better information it would be appreciated. I was hoping to go to somehting much beefier if possible ? Link to comment Share on other sites More sharing options...
chucktoo Posted June 28, 2005 Author Share Posted June 28, 2005 Hi This was the best I could find for longer replacements - title is wrong factory is m12x1.25. http://www.courtesyparts.com/nismo/bolts/index.html Thanks for all the suggestoins Link to comment Share on other sites More sharing options...
