ACE THIS Posted June 24, 2005 Share Posted June 24, 2005 Anyone who has the new legacy, could u tell me how she starts under really really cold weather... when i was starting it in my driveway i noticed that it kinda turns over a little slower than my pervious car... any problems. start right away???? Also, does anyone know what numbers subaru puts out of their cars. How many a year sold, etc.? Link to comment Share on other sites More sharing options...
Martyr Posted June 24, 2005 Share Posted June 24, 2005 My 05 Legacy seems to start "slower" and with less enthusiasm than did my Acura or Ford cars. My 02 WRX did the same thing, so I just chalked it up as a character trait of the Subaru boxer engine. I've never had it NOT start up after turning over 3-4 times. It could be that your battery was run low on the dealer lot (very common), so you might give your battery a full charge and see if that helps. Martyr Link to comment Share on other sites More sharing options...
melayout Posted June 25, 2005 Share Posted June 25, 2005 Also in the winter, I don't crank it right away after I've entered the key, I turn the key to the ON position, wait for the fuel pressure to build up a lil and for all the electrical components to be charged then I crank and it never failed or took more than usual to start up. I keed I keeed Link to comment Share on other sites More sharing options...
franklin Posted June 25, 2005 Share Posted June 25, 2005 Mine always started but cranked slow. I think the problem is the stock battery 400 CCA Try an Optima group 35 this is 720 CCAmps. Link to comment Share on other sites More sharing options...
rony Posted June 25, 2005 Share Posted June 25, 2005 Nah, I think it's just a subaru thing.. My Car vBGarage Link to comment Share on other sites More sharing options...
rallispec Posted June 25, 2005 Share Posted June 25, 2005 subaru thing -- and like melayout said, i usually turn the key half way to get the electronic stuff on wait a half second or so, and then turn the car on. Link to comment Share on other sites More sharing options...
rts Posted June 25, 2005 Share Posted June 25, 2005 Mine cranks slower than my previous cars too but has always started fine. Link to comment Share on other sites More sharing options...
sbyates Posted June 25, 2005 Share Posted June 25, 2005 My Subie starts really really slow in the winter but, it might just be the -50 weather we have here. Link to comment Share on other sites More sharing options...
melayout Posted June 25, 2005 Share Posted June 25, 2005 My Subie starts really really slow in the winter but, it might just be the -50 weather we have here. Using some 0-W30 Synthetic Oil should make the engine start easier, plus reduces a lot of wear and tear, which is most significant when starting the engine. http://www.mobil1.com/USA-English/MotorOil/Oils/Mobil_1_0W-30.aspx Flows at -53F and protects to 400F. I keed I keeed Link to comment Share on other sites More sharing options...
sbyates Posted June 25, 2005 Share Posted June 25, 2005 Hey, good call that's the same oil I give the Subie dealer when I go in for service.Thanks for the advice Link to comment Share on other sites More sharing options...
VXCL Posted June 25, 2005 Share Posted June 25, 2005 Mine always started but cranked slow. I think the problem is the stock battery 400 CCA Try an Optima group 35 this is 720 CCAmps. http://mywebpages.comcast.net/vx16.temp/legacyoptima.jpg http://mywebpages.comcast.net/vx16.temp/legacyoptima3.jpg oem batt is a joke. it didn't really change the way the car starts, however lights no longer dim when down shifting MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
franklin Posted June 25, 2005 Share Posted June 25, 2005 So none of you guys think that the cranking speed/starting would change much between 400 and 720 amps? Its just a Subaru thing right. Link to comment Share on other sites More sharing options...
Mr. CentralOhioSubarus Posted June 25, 2005 Share Posted June 25, 2005 Every Subaru I've had does this. I've also never had one fail to start though. Link to comment Share on other sites More sharing options...
