Mike C Posted June 24, 2005 Share Posted June 24, 2005 In preparation for an upgraded turbo, I was considering installing an STI TMIC/intake manifold. Can anyone comment on how challenging the install is? Thanks, Mike Link to comment Share on other sites More sharing options...
Mike C Posted June 24, 2005 Author Share Posted June 24, 2005 Also, is the STI TMIC less/more efficient that the stock GT one? Link to comment Share on other sites More sharing options...
rao Posted June 24, 2005 Share Posted June 24, 2005 The answer depends on your experience, it is easier than rebuuilding a transmission and harder than changing the oil. No changing anything just taking things off and putting things on. (I am basing this on swapping manifolds on WRXs. Nobody knows the answer to your second question, at leaast not anybody that is willing to share. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mike C Posted June 24, 2005 Author Share Posted June 24, 2005 Understood, I'm pretty comfortable with maintenance items, and basic mods such as STS, shifter bushings, uppipe/downpipe, exhaust. I didn't see a walkthrough for the intake manifold, so I wasn't sure how labor intensive it was. The answer depends on your experience, it is easier than rebuuilding a transmission and harder than changing the oil. No changing anything just taking things off and putting things on. (I am basing this on swapping manifolds on WRXs. Nobody knows the answer to your second question, at leaast not anybody that is willing to share. Link to comment Share on other sites More sharing options...
rao Posted June 24, 2005 Share Posted June 24, 2005 The only thing that I would expect to spend some time on is the routing of all of the vacuum hoses. Everything is genreally the same, but not the exact locations. Keep in m ind that you will need 4 gaskets because of the TGVs. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mike C Posted June 24, 2005 Author Share Posted June 24, 2005 Thanks, since no one can answer my 2nd question, I'll probably hold off until I'm sure i'm going to get a new turbo. Link to comment Share on other sites More sharing options...
rao Posted June 24, 2005 Share Posted June 24, 2005 Getting an accurate asnwer to that question will be quite difficult. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
firedawgs Posted June 25, 2005 Share Posted June 25, 2005 Just to let you know. The STi intake manifold is not a direct fit. There is/are a couple of customizing tweaks you have to do to make it fit. Updated my vBGarage: Link to comment Share on other sites More sharing options...
rc0032 Posted June 25, 2005 Share Posted June 25, 2005 Thanks, since no one can answer my 2nd question, I'll probably hold off until I'm sure i'm going to get a new turbo.Why not go with a 20g? The cost will be about the same as STi manifold + turbo. Link to comment Share on other sites More sharing options...
Mike C Posted June 25, 2005 Author Share Posted June 25, 2005 That's a direct bolt on w/o the need for other mods? Why not go with a 20g? The cost will be about the same as STi manifold + turbo. Link to comment Share on other sites More sharing options...
rc0032 Posted June 25, 2005 Share Posted June 25, 2005 That's a direct bolt on w/o the need for other mods?You will need supporting mods and a custom tune for both paths. Injectors and fuel delivery. Link to comment Share on other sites More sharing options...
rao Posted June 25, 2005 Share Posted June 25, 2005 But it's not pink!!! Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
