GT_Red Posted December 10, 2011 Share Posted December 10, 2011 Ok, so when I got my clutch replaced they told me the driver's side boot was torn all the way around. Had it replaced last year, bummer. Anyways, I am going with a new axle since the boot replacement is a joke and costs just as much in labor. Anywhoo, I am looking at the Empi 80-5531 ($57.95 Amazon), and wanted to know if anyone has experience with this and just to make sure its the right part #. From other posts it appears so, however, some posts and even Amazon can get it wrong sometimes. Thanks in advance! Link to comment Share on other sites More sharing options...
Th3Franz Posted December 12, 2011 Share Posted December 12, 2011 I'm running EMPI front axles. Aside from surface rust, they seem to be working fine with 300whp. I did recently have an axle seal go out after a year, but I don't think it's related to the replacement axles. Did a clutch job last fall with new seals, but one of them must not have been quite right. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
GT_Red Posted December 12, 2011 Author Share Posted December 12, 2011 WTF is up with the boots on these things? They just break like its nothing. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2011 Share Posted December 12, 2011 It's called old age. Happens to lots of cars. Aug 2010 my left front boot tore. I bought a 100% new $80.00 axle from Advance Auto parts, They didn't have one in the store but had it there in 45 minutes. They got it from Autopart International which was about a mile away. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GT_Red Posted December 13, 2011 Author Share Posted December 13, 2011 Yeah but I replaced the boot barely a year ago. It has a new boot on it! Gonna buy an EMPI axle for it. Should I just go ahead and replace both axles? Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 13, 2011 Share Posted December 13, 2011 Why would you replace both? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
compsurge Posted December 13, 2011 Share Posted December 13, 2011 The heat from the downpipe has a lot to do with the failures as well. BAC is the forum champion of heat wrap and insulation - seriously is a very nice setup. Link to comment Share on other sites More sharing options...
GT_Red Posted December 14, 2011 Author Share Posted December 14, 2011 According to EMPI's description, they have made a thicker more robust boot and joint, I dunno, it seems the specs are a little different and therefore would replace both just to keep things evened out. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 14, 2011 Share Posted December 14, 2011 If it aint broke don't fix it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
