mwiener2 Posted December 6, 2011 Share Posted December 6, 2011 When it reaches the top of the F mark on the dipstick, you are full. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted December 6, 2011 Mega Users Share Posted December 6, 2011 Lol Link to comment Share on other sites More sharing options...
bmx045 Posted December 6, 2011 Share Posted December 6, 2011 had nooooo idea what i meant was, how much can you fill before problems occur Link to comment Share on other sites More sharing options...
mwiener2 Posted December 6, 2011 Share Posted December 6, 2011 I would guess at around 6-7qts you'll be flooding the crankcase. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bmx045 Posted December 6, 2011 Share Posted December 6, 2011 I assume a pcv cel would occur? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 6, 2011 Share Posted December 6, 2011 probably not till after the damage was done My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
RabidWombat Posted December 6, 2011 Share Posted December 6, 2011 Are you sure the dip stick was full and not empty. I definitely encountered an issue with my Volvo. I'd gotten the oil changed then started a long road trip. When I stopped for gas it seemed like it was empty or near empty. I added a quart of oil, next tank same thing. I took the car too a garage, I'd overfilled by 2+ qts. The oil was almost perfectly clear and was actually above the full mark so you couldn't properly read the dipstick. I suspect the person who blew the engine by adding 4 qts did the same thing. Link to comment Share on other sites More sharing options...
mwiener2 Posted December 6, 2011 Share Posted December 6, 2011 The engine was blown before the addition of more oil, I believe. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
enaggs37 Posted December 7, 2011 Author Share Posted December 7, 2011 I checked the oil when the car was off, on level ground, and yes the dipstick was fully inserted. I always make sure my dipstick gets fully inserted when I check my gf's oil....LMAO!! Sorry....had to say that!! Anyways, I guess my question is this....If the oil was low, why didnt an indicator light come on in my instrument cluster?? I realize I'm now fucked and eating the cost on this whole thing....just curious as to why it happend. BTW....I would still buy another Subie!!! Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted December 7, 2011 Share Posted December 7, 2011 Without knowing all the facts it is anyone's guess as to what happened to cause your engine to blow. It is just not that common for engines to fail like this with low miles unless maintenance was neglected. Link to comment Share on other sites More sharing options...
FLZ_Boy Posted December 7, 2011 Share Posted December 7, 2011 I checked the oil when the car was off, on level ground, and yes the dipstick was fully inserted. I always make sure my dipstick gets fully inserted when I check my gf's oil....LMAO!! Sorry....had to say that!! Anyways, I guess my question is this....If the oil was low, why didnt an indicator light come on in my instrument cluster?? I realize I'm now fucked and eating the cost on this whole thing....just curious as to why it happend. BTW....I would still buy another Subie!!! Was it immediately you checked the oil after the car was turned off or an hour later? Link to comment Share on other sites More sharing options...
Kodax Posted December 7, 2011 Share Posted December 7, 2011 This is indeed very strange for Subaru NA engines to blow. I check the oil in my 3.0R quite regularly and it seems pretty constant in between the intervals of oil changes. Link to comment Share on other sites More sharing options...
mwiener2 Posted December 7, 2011 Share Posted December 7, 2011 If the oil was low, why didnt an indicator light come on in my instrument cluster?? Because there is no low oil sensor My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bmx045 Posted December 7, 2011 Share Posted December 7, 2011 there is no oil level light or sensor, only oil pressure, which happens to illuminate at obsurdly low psi in which damage has already occurred by then. It's considered a replace engine light. Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted December 7, 2011 Share Posted December 7, 2011 This is indeed very strange for Subaru NA engines to blow. I check the oil in my 3.0R quite regularly and it seems pretty constant in between the intervals of oil changes. Just had a guy here locally blow his engine(...well started rod knock, which will result in a rebuild) in an 07 2.5i during a rallyx event last Saturday. Link to comment Share on other sites More sharing options...
mwiener2 Posted December 7, 2011 Share Posted December 7, 2011 Because racecar My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
enaggs37 Posted December 7, 2011 Author Share Posted December 7, 2011 Was it immediately you checked the oil after the car was turned off or an hour later? Yes!! Immediately...in fact, I was already pulling over when I heard the noise, of which, the ck eng light/oil psi light came on. I would say it was less than 1:30 mins when the oil was checked. Link to comment Share on other sites More sharing options...
PrimeRib Posted December 11, 2011 Share Posted December 11, 2011 I'm interested to hear how you make out. Link to comment Share on other sites More sharing options...
naimouasta Posted December 12, 2011 Share Posted December 12, 2011 Yes!! Immediately...in fact, I was already pulling over when I heard the noise, of which, the ck eng light/oil psi light came on. I would say it was less than 1:30 mins when the oil was checked. i believe you have to wait atleast 5-10mins before you can check the oil. says so in the manual too. Link to comment Share on other sites More sharing options...
thestratomaster Posted December 14, 2011 Share Posted December 14, 2011 my brother's motor blew up on his OBS at 36k. shitty that yours seems to have a serious oil consumption problem Link to comment Share on other sites More sharing options...
