chico_192 Posted November 12, 2011 Share Posted November 12, 2011 I put a cd into my radio deck earlier and suddenly my head unit just lost all power to it, is there a fuse i should be checking? if so which one? or if it could be anything else all help is appreciated thanks Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 12, 2011 I Donated Share Posted November 12, 2011 Yes there is a fuse for it under the dash. I don't remember what one it is..... The fuse box is close to where your left foot sits while your driving. You have to lay on your back to be able to see it. I don't remember what fuse in the box it is. Just pull them out one at a time and check each one. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
chico_192 Posted November 12, 2011 Author Share Posted November 12, 2011 Okay thanks man, i figured it had to be one of them just didnt know which one Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 12, 2011 I Donated Share Posted November 12, 2011 Yeah, I cant remember what one it is. Just pull them one at a time until you find it. Its only like 2 minutes of work -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
chico_192 Posted November 13, 2011 Author Share Posted November 13, 2011 yeah, i didnt even notice there was one labeled "radio" fuse was good, head unit is shot Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 13, 2011 Share Posted November 13, 2011 Check the wiring behind the unit before you declare the unit dead. A buddy of mine recently put a pioneer in and he was having this problem of it working one day and not the next and when I took it out it was because the ground connection was bad. Link to comment Share on other sites More sharing options...
chico_192 Posted November 13, 2011 Author Share Posted November 13, 2011 alright thanks i'll have to check it all out again, mine is also a pioneer, yeah exactly because at some points it was working when i took it out and others it didn't have any power Link to comment Share on other sites More sharing options...
stevenva Posted November 14, 2011 Share Posted November 14, 2011 The radio has 2 power wires, Switched 12V and constant 12V (keeps station presets-clock). Both must work for the radio to operate. The fuse labled radio is for the switched (red wire), the fuse for the power mirrors also powers the radios constant (yellow wire). It's kinda rare for a radio to blow a fuse though. What are you using for a ground? Are you using some plastic mounting kit (bad) or are you using the (proper) factory steel, side ISO brackets? If it's the plastic kit option, are you just relying on the antennas' ground shield to get your ground? RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
