VinceAD Posted November 12, 2011 Share Posted November 12, 2011 I am having trouble getting the large bolt off the spindle. Instead of a cotter pin being through the spindle the outside of the nut is bent down into a channel at the end of the spindle. To get the nut to move you have to bend it out. I can't seem to get a screwdriver tip small enough in there to bend it out. Anyone ever remove the nut and what did you do to bend it out? Thanks for any help. Vince Link to comment Share on other sites More sharing options...
VinceAD Posted November 12, 2011 Author Share Posted November 12, 2011 Here is a picture. http://www.facebook.com/photo.php?fbid=2193902643575&set=a.1446380475988.2064383.1127453516&type=1&theater If the pic doesn't show up please follow this link. http://www.facebook.com/photo.php?fbid=2193902643575&set=a.1446380475988.2064383.1127453516&type=1&theater Link to comment Share on other sites More sharing options...
mwm5094 Posted November 13, 2011 Share Posted November 13, 2011 I just replaced 2 axles and all wheel bearings so I had to take all of mine off. I used a punch. One that is used for finishing nails. Just dont make the mistake to try to pry bc mine broke. Also, do you have air tools? It will be WAY easier to get the nut off with them. Link to comment Share on other sites More sharing options...
bluesuby Posted November 13, 2011 Share Posted November 13, 2011 You do realize the warranty on rear wheel bearings was extended to 100,000 miles? Link to comment Share on other sites More sharing options...
doobaruGT Posted November 13, 2011 Share Posted November 13, 2011 FYI, you don't need to bend the notched piece out...that central hub bolt is independent of that "locking" mechanism you're seeing. I've done mine and I just used a large socket wrench and took the handle apart on my jack, put that over the wrench for extra torque, and BINGO! It just requires A LOT of torque to get it off....GL! Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
slowGT Posted November 13, 2011 Share Posted November 13, 2011 Its a pain to unbend... I broke the tips on a few small screwdrivers. I ended up using a chisel. I ground the tip of the chisel in half so that it was thin enough to fit in the square keyway. I wish they would have either used a cotter pin, or a spindle nut and square woodruff key. Oh well keep at it, it's a pain but it will unbend. Link to comment Share on other sites More sharing options...
doobaruGT Posted November 13, 2011 Share Posted November 13, 2011 Again...you don't need to bend it out....just turn with a ton of torque :-) Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
slowGT Posted November 13, 2011 Share Posted November 13, 2011 I was worried about damaging the threads by not unbending it. But yeah, I didn't unbend it all the way and I was okay. If you were okay then go to town with the impact gun (only to remove the bolt). Link to comment Share on other sites More sharing options...
VinceAD Posted November 14, 2011 Author Share Posted November 14, 2011 Thanks all for the replies. I tried turning with it bent, but didn't have enough umph to budge it. Ended up using a punch and bending it out. The roaring from the bearings is gone now, thanks again to all with your replies and help. Link to comment Share on other sites More sharing options...
