Chris GTO TT Posted November 8, 2011 Share Posted November 8, 2011 Its best to have the receipt yourself otherwise it runs through the member number. I recommend just giving your friend $20 or so and having them get you a couple gift cards for $10 that way you can go in when you want. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
eldiablo Posted November 8, 2011 Share Posted November 8, 2011 My Wal-Mart battery has been working fine for over 18 months and worked fine in sub-zero temps last winter. My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2011 Share Posted November 8, 2011 I know what not to get. A walmart brand battery. No bueno. They last like a year. I installed my Walmart Maxx Everstart Oct 11 09, it's still working fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 8, 2011 Author Share Posted November 8, 2011 got the battery tested this morning before work and the guy said it was cranking out a wicked 2 amps. FYI this is the stock battery in my 08 LGT its 430cca's http://i529.photobucket.com/albums/dd340/Jay04WRX/d2f05371.jpg I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 8, 2011 Author Share Posted November 8, 2011 A friend of mine sent me this article which states that Johnson Controlls basically makes most batteries we buy and see on the market even OEM batteries http://bestbatterytips.com/tags/who-makes-kirkland-batteries/ I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
Scrad Posted November 9, 2011 Share Posted November 9, 2011 I got a Duralast Gold from Autozone and it was a great battery up here in the cold Wisconsin winters. I've replaced a few OEM batteries with Duralasts and have always been happy. But like others have said there are only about 3 battery manufactures so most are just rebranded with different warranties. Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 9, 2011 Share Posted November 9, 2011 I knew JC made Optima batteries, but I didn't know they made most others. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
BigBlack-V Posted November 9, 2011 Author Share Posted November 9, 2011 Strange question but i disconnected the old battery yesterday morning car was dead. Hooked up the new one this morning (kirkland 640cca) and drove it to work however it didnt drive like it did prior. Since the battery was disconnected does the AP need to relearn my driving again? I was in 5th on the highway when the car hit boost then it felt like it stopped spooling. I tried to repeat it but it didnt work the 2nd time. Car almost feels slugish with the new battery kinda hard to explain. I think the ECU/AP need to learn all over again, what do you think? I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2011 Share Posted November 9, 2011 May be seeing as how it was down for so long. I didn't notice any difference when mine was replace... before it went bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mustangendsley Posted November 9, 2011 Share Posted November 9, 2011 Duralast Gold is a great one to get. Link to comment Share on other sites More sharing options...
Scrad Posted November 9, 2011 Share Posted November 9, 2011 Strange question but i disconnected the old battery yesterday morning car was dead. Hooked up the new one this morning (kirkland 640cca) and drove it to work however it didnt drive like it did prior. Since the battery was disconnected does the AP need to relearn my driving again? I was in 5th on the highway when the car hit boost then it felt like it stopped spooling. I tried to repeat it but it didnt work the 2nd time. Car almost feels slugish with the new battery kinda hard to explain. I think the ECU/AP need to learn all over again, what do you think? Yes, the ECU will need to relearn your driving style. Your AP might have went back to the stock/base map. You might might have to reflash the tuned/realtime map back on top. So drive it hard. It will be fine after a few miles. Link to comment Share on other sites More sharing options...
JJay03 Posted January 3, 2012 Share Posted January 3, 2012 I had a walmart battery in my wifes car that barely lasted a year. I had an interstate battery in my last beater and that thing lasted forever. Im currently trying to decide on a battery for my legacy though. Link to comment Share on other sites More sharing options...
mwm5094 Posted January 3, 2012 Share Posted January 3, 2012 love my red top Link to comment Share on other sites More sharing options...
SP3C7R3 Posted January 4, 2012 Share Posted January 4, 2012 +1 for Interstate. Link to comment Share on other sites More sharing options...
Adrenaline Posted January 4, 2012 Share Posted January 4, 2012 One with good warranty. Link to comment Share on other sites More sharing options...
theflystyle Posted January 5, 2012 Share Posted January 5, 2012 one thing that hasent been mentioned here is batteries and their weights.... "good quality" batteries can be near 50lbs (referencing die hard platinum here) while others are typically 30-40ish... That may be something for other to consider as well. Link to comment Share on other sites More sharing options...
