Havok1212 Posted October 25, 2011 Share Posted October 25, 2011 1. i know the 04 sti's had banjo bolt filters and it was good to remove them to prevent them from clogging up. i was wondering if the 2005 lgt have them and if we should remove them. 2. is boost creep really common if i have a stock tune with my only mod being a catless turbo back.3. what tune should i get for a safe daily driver not caring how much power i put down only a tune for under 500$ Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2011 Share Posted October 25, 2011 1. yes, remove it. 2. yes. get it tuned, stay out of boost. 3. Do you have a lap top ? are you good with it ? you can get cables and buy a tune from one of the on line Tuners. I use http://www.tuningalliance.com for my Tuning needs. Did you remove the cat in the up pipe ? that's something you need to do too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Havok1212 Posted October 25, 2011 Author Share Posted October 25, 2011 no i still have the stock up pipe Link to comment Share on other sites More sharing options...
Havok1212 Posted October 25, 2011 Author Share Posted October 25, 2011 should i just gut the up pipe? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2011 Share Posted October 25, 2011 You can get a catless up pipe for under 100.00 - 150.00 Besides the aftermarket up pipe will flow better. May be find one used. You'll need a 2.2k-Ohm resistor for the egt sensor you remove too. It's a $1.25 from radio shack. p/n271-1121 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2011 Share Posted October 25, 2011 http://legacygt.com/forums/showthread.php/fs-hi-perrin-dp-172986.html There just found that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
5hift Posted October 26, 2011 Share Posted October 26, 2011 You can get a catless up pipe for under 100.00 - 150.00 Besides the aftermarket up pipe will flow better. May be find one used. You'll need a 2.2k-Ohm resistor for the egt sensor you remove too. It's a $1.25 from radio shack. p/n271-1121 Very informative. Thanks for sharing. Just got an OXT, need to learn more how to make my new ride better. Link to comment Share on other sites More sharing options...
Havok1212 Posted October 26, 2011 Author Share Posted October 26, 2011 yea i saw that one...where do you hook up the resistor at Link to comment Share on other sites More sharing options...
BigTDogg MA Posted October 26, 2011 Share Posted October 26, 2011 On connector which usually goes to the EGT. Just plug it in so the connections to the terminals are secure, then heat shrink/electrical tape that bitch up. A used STI up pipe can be had for around $75 or less. A gutted OEM pipe is garbage. Link to comment Share on other sites More sharing options...
Havok1212 Posted November 3, 2011 Author Share Posted November 3, 2011 how much boost does it run from the factory? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 3, 2011 Share Posted November 3, 2011 Like 13.5psi I think. Get the Uppipe/ Downpipe / tune and you can turn that into 17psi Link to comment Share on other sites More sharing options...
Havok1212 Posted November 3, 2011 Author Share Posted November 3, 2011 Like 13.5psi I think. Get the Uppipe/ Downpipe / tune and you can turn that into 17psi On the factory boost crontroller? If not what brand would you recommend Link to comment Share on other sites More sharing options...
bmx045 Posted November 3, 2011 Share Posted November 3, 2011 the factory boost controller is good to about 19psi. anything over will require an ebcs (grimmspeed 3port). At stage 2, you should keep the stock one. stg 2 tunes are only 18-19psi anyway, unless you get a fmic- then an ebcs is a good edition. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 3, 2011 Share Posted November 3, 2011 You can get a catless up pipe for under 100.00 - 150.00 Besides the aftermarket up pipe will flow better. May be find one used. sorry to hijack, but is a catless up pipe illegal? I am just wondering cause it'd mean no more catalytic converter, and therefore "toxic crap" is not getting filtered? How do you guys all pass your emission test with catless? Not trying to get in an argument, just curious. Link to comment Share on other sites More sharing options...
blongo804 Posted November 3, 2011 Share Posted November 3, 2011 Nope. You're just fine with a catless uppipe. Actually, I believe it started in '07 for the LGT's that Subaru removed the cat from the uppipe themselves. Link to comment Share on other sites More sharing options...
bmx045 Posted November 3, 2011 Share Posted November 3, 2011 Nope. You're just fine with a catless uppipe. Actually, I believe it started in '07 for the LGT's that Subaru removed the cat from the uppipe themselves. 07+ was catless in the uppipe. The two cats in the downpipe are enough to pass inspection, and so is 1 cat in aftermarket downpipes. I have no cats and pass inspection Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 3, 2011 Share Posted November 3, 2011 I guess I show my ignorance. I did not know there was more than one cat.. Link to comment Share on other sites More sharing options...
Havok1212 Posted November 3, 2011 Author Share Posted November 3, 2011 I don't have emission testing where I live and I have some friends in high places for my state inspections. Which means zero cats on the car for me Link to comment Share on other sites More sharing options...
Havok1212 Posted November 5, 2011 Author Share Posted November 5, 2011 Like 13.5psi I think. Get the Uppipe/ Downpipe / tune and you can turn that into 17psi Does it run 17 psi automatically bc of the free flowing exhaust? Or do I have to adjust the psi my self to reach 17psi. Sorry for all the noob questions This is my first boxer engine Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 5, 2011 Mega Users Share Posted November 5, 2011 A stage 2 tune will do that for you. You should avoid boost with a dp and no tune! Link to comment Share on other sites More sharing options...
Havok1212 Posted November 6, 2011 Author Share Posted November 6, 2011 Safe to have a Perrin intake with stage 2? Link to comment Share on other sites More sharing options...
frank_ster Posted November 6, 2011 Share Posted November 6, 2011 i don't have to run a cat but i do for the sake of the environment a good high flow cat will make the car quieter and cleaner with out loss of power . Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
bmx045 Posted November 6, 2011 Share Posted November 6, 2011 None of the accessport tunes support an aftermarket intake. Regardless of what you do you need it to be open source tuned. Link to comment Share on other sites More sharing options...
