m sprank Posted September 29, 2011 Share Posted September 29, 2011 So, If you are running big boost (23psi or more) you are maxing out the OEM 2.5Bar MAP sensor. After much research the cheapest, most accurate solution seems to be the GM 3BAR MAP Sensor. Which GM sensor though is VERY important. Only the MAP sensor out of a 1989 TransAm 3.8l V-6 Turbo will work. GM part number is 12223861. I found one at NAPA for $65. NAPA part number is 2-19481. You will need a GM electrical pigtail too. GM part number is 15305891. Install is straight forward. Terminals; A=Ground (Black with yellow stripe on LGT) B=Signal (Orange on LGT) C=5V (Black with blue stripe on LGT) Just splice the GM pigtail into your harness and find a suitable mounting location. Then connect the tube from the manifold. Now you need to rescale the sensor. On 2007+ cars with the air pump this is sooo important. If you do not rescale the car will not start. You will throw P2431. This is the secondary air system sensor verifying atmospheric pressure. If atmospheric and manifold pressure are vastly different at key in on position, no start. Now for scaling. I use Romraider which allows an offset and a multiplier. The cutsheet on the GM sensor shows a voltage of 0.501-0.761 at 40kPa. It shows a voltage of 4.784-5.044 at 304kPa. So, if Y = MX + B, then 304-40 = 264kPa (0.501 + 0.76) / 2 = 0.631v (4.784 + 5.044) / 2 = 4.914v 4.914v - 0.631v = 4.283v avg difference 264kPa / 4.283v = 61.639kPa/v 304kPa = (61.639kPa x 4.914v) + B B = 1.106kPa 61.639kPa = 8.9399psi this is your multiplier 1.106kPa = 0.1604psi this is your offset Offset on this equation is a bit odd. Multiplier is always stable. Here is the reason. Depending on when you convert to psi the offset changes. If you convert to psi right from the beginning you get an offset of 0.1608. If you convert to psi at the end you get 0.1882. So, I took the average of the two which is 0.1745. So my final (pre-boost gauge verification) scaling is; Offset = 0.1745 Multiplier = 8.9399 Per the GM cutsheet the max voltage should be set to 4.94v. Minimum voltage should be set to 0.02v. I left the CEL threshold at 8. These settings give me a reading of 14.4psi with the car off and ignition on at sea level. I used my Fluke and verified the sensor is putting out 1.606vdc stable. But the ecu is reading 1.577vdc. Not sure where the voltage drop is occurring. Not sure if it is stable (I need a boost gauge). Because of this I adjusted the offset to 0.6045. This is giving me a reading of 14.65psi which is exactly what it read stock. I I have verified the scaling with a boost gauge. But, every sensor will have slight variance and every car will too. I hope this helps anyone else who is currently running or planning to run more boost than the 22.5psi that the OEM MAP is capable of handling. Link to comment Share on other sites More sharing options...
rao Posted September 29, 2011 Share Posted September 29, 2011 You would use GM parts in a Subaru Great info gathered into one place Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
m sprank Posted September 30, 2011 Author Share Posted September 30, 2011 Would use them in a BMW too, Lol. Cheapest thing I could find to do the job. Kind of like an LS-1 swap. Link to comment Share on other sites More sharing options...
Spec B Posted October 1, 2012 Share Posted October 1, 2012 Bumping this up for a little help. Looking to go to a bigger MAP sensor - wondering if anyone has tried this scaling on a 05-06? I am still on the stock MAP sensor and my boost STRI electronic boost gauge is reading 24.5 PSI - although I am barely hitting 22 (21.85) when I log. I need scaling will be pretty close since my boost gauge is way off. Link to comment Share on other sites More sharing options...
m sprank Posted October 1, 2012 Author Share Posted October 1, 2012 Scaling on 05-06 should be the same. You will need some info from the sensor manufacturer and you can then plug the numbers into the equation. Many customers using the AEM 3 and 5 bar sensors and the Perrin sensors. Link to comment Share on other sites More sharing options...
gordata Posted September 11, 2013 Share Posted September 11, 2013 Sorry for bumping this but where is a good place to mount the 3 Bar Sensor? I was looking for a bracket if one existed but did not find much info for legacy/wrx application, only for metal manifold. Link to comment Share on other sites More sharing options...
m sprank Posted September 11, 2013 Author Share Posted September 11, 2013 Where ever you feel like it. Depends on how much wiring you want to do. If using a GM you will have to get creative for a mount. Link to comment Share on other sites More sharing options...
gordata Posted September 11, 2013 Share Posted September 11, 2013 Any pictures of where you have it mounted so I can steal some of your idea? Lol Sent from my Nexus 10 using Tapatalk 4 Link to comment Share on other sites More sharing options...
m sprank Posted September 11, 2013 Author Share Posted September 11, 2013 I ran it for about 1 month. It was a band aid. I made a custom aluminum mount for it. I use AEM sensors otherwise. Link to comment Share on other sites More sharing options...
acumenhokie Posted September 21, 2013 Share Posted September 21, 2013 Does this apply to 5th gen LGT too? Link to comment Share on other sites More sharing options...
m sprank Posted September 22, 2013 Author Share Posted September 22, 2013 Scaling is scaling. The math is always the same. Every sensor (Omni, AEM, etc) have different scaling. I have never swapped a MAP sensor on a 5th gen. You would need the wiring diagram to verify power/ground/signal and then you would need to re-scale the sensor via the AP tuning software or Ecutek (whichever you are tuning with). Link to comment Share on other sites More sharing options...
