macdarwin Posted September 29, 2011 Share Posted September 29, 2011 Just discovered a problem while going on the highway yesterday and I thought it was just a tire making a humming noise and when the humming went away, today a sound like thud like running over a numerous stone with lots of play on the steering wheel and vibration on the whole car while going 65+ on the highway. If i let the car roll by itself (automatic) I can hear that noice like running over a small rock. but in reverse its quiet. I feel this in the front. So is this could be the Infamous Bearing or the axle? Car is a 2007 with 50k miles so I guess this is out of the warranty. This is what I saw by looking under neat the car. I really need your Opinion, thanks! http://i15.photobucket.com/albums/a394/macdarwin/IMG_20110929_021349.jpg Link to comment Share on other sites More sharing options...
m sprank Posted September 29, 2011 Share Posted September 29, 2011 Outer strap is loose. Standard Subaru. Grease is being thrown from the CV boot. Strap is not holding. Chances are CV joint could be damaged. Maybe not. But you are hearing noises. See far more CV joints go than wheel bearings. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 29, 2011 Share Posted September 29, 2011 isn't it 5 years or 60,000 miles ? Call the dealer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cseagle08 Posted October 1, 2011 Share Posted October 1, 2011 Also check the u-joints in the drive-shaft to the rear. But probably is a front axle related issue. Link to comment Share on other sites More sharing options...
