cucamelsmd15 Posted September 14, 2011 Share Posted September 14, 2011 Noticed when having new tires put on last night that all four shocks/struts are leaking. KYB GR2s are already on the way to fix that problem. The more concerning thing is that the LCA rear bushings are cracked badly, and about 1/3 of the drivers side bushings is missing. What are my replacement options? I know the stock bushings are cheap, but I also dont want to be pulling LCAs again in 40k because they are shot. Polyurethane? Better rubber? Link to comment Share on other sites More sharing options...
bmx045 Posted September 14, 2011 Share Posted September 14, 2011 http://www.fredbeansparts.com/index.php/avo-subaru-legacy-gt-0-00-lower-arm-bushing-kit.html /thread. Link to comment Share on other sites More sharing options...
Geegeez Posted September 14, 2011 Share Posted September 14, 2011 Anyone tried Whiteline W0506 Front LCA bushings? How do those compare to the AVO? Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 14, 2011 Share Posted September 14, 2011 After somewhat poor luck with AVO products, I decided to go Whiteline throughout for bushings. They've always served me well. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Boost_addict Posted September 20, 2011 Share Posted September 20, 2011 I installed a set of the upgrade 20204AG011 lca rear busings over the weekend. Very nice upgrade over my torn stockers. I was going to install the sti fronts 20204AJ000 but my stockers looked in good shape still and there is so littler rubber for movement I left them alone. For <$30/ea shipped its hard to beat the 20204AG011 if you currently have torn stockers IMO. Link to comment Share on other sites More sharing options...
rlineberg Posted September 20, 2011 Share Posted September 20, 2011 I installed a set of the upgrade 20204AG011 lca rear busings over the weekend. Very nice upgrade over my torn stockers. I was going to install the sti fronts 20204AJ000 but my stockers looked in good shape still and there is so littler rubber for movement I left them alone. For <$30/ea shipped its hard to beat the 20204AG011 if you currently have torn stockers IMO. Did you press the rear LCA bushings out yourself and if so what did you use? Link to comment Share on other sites More sharing options...
Boost_addict Posted September 20, 2011 Share Posted September 20, 2011 I used a harbor freight press. Worked fine with some misc steel tubing and sockets for fixturing. Link to comment Share on other sites More sharing options...
boosten-n-bluntin Posted September 23, 2011 Share Posted September 23, 2011 I have had both avo and whiteline.. whiteline is the way to go, simply for the fact they are adjustable Link to comment Share on other sites More sharing options...
soloz2 Posted September 23, 2011 Share Posted September 23, 2011 I have Whiteline front and rear LCA bushings. Installed at the same time as steering rack bushings and they feel great! Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
cucamelsmd15 Posted September 23, 2011 Author Share Posted September 23, 2011 Where can one find the Whiteline bushings? Its for a stock daily driver, so Id rather not deal with the NVH of harder stuff, even if that means putting a rubber set back in. Link to comment Share on other sites More sharing options...
boosten-n-bluntin Posted September 24, 2011 Share Posted September 24, 2011 Fredbeans.. part # kca334 Link to comment Share on other sites More sharing options...
soloz2 Posted September 24, 2011 Share Posted September 24, 2011 My car is a DD. I've never tracked it and probably never will. It's a 2.5i so not that fast anyway... But the Whiteline LCA bushings paired with steering rack bushings and my initial thought was "Wow, this is what the car should have been like from the factory!" There is minor NVH, but not bad. Fine for a DD. Really tightened the front up in a more dramatic way than my 20mm JDM RSB did for the rear IMHO Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
