collier89139 Posted September 10, 2011 Share Posted September 10, 2011 Does anyone have a diagram of the location of the crankshaft position sensor on a 1996 Legacy LS AWD. I keep getting the code that says it is bad. I am thinking about just cleaning it out to see if that helps Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 10, 2011 Share Posted September 10, 2011 Its in the center of the engine under the front of the alternator behind the pulley un plug the harness one bolt and pull up and its out. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 10, 2011 I Donated Share Posted September 10, 2011 Its right above the back of thee crank pulley -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
lulzcow Posted September 10, 2011 Share Posted September 10, 2011 if you have a new one in hand, it will be extremely easy to locate in that area, and easy to replace. boxer engine layout ftw Link to comment Share on other sites More sharing options...
Osei Posted September 11, 2011 Share Posted September 11, 2011 part#18 here http://opposedforces.com/parts/legacy/us_b11/type_7/engine/piston_and_crankshaft/illustration_1/ Here is link to fsm http://www.main.experiencetherave.com/subaru_manual_scans/ and for future ref http://opposedforces.com/parts/legacy/us_b11/ O. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 11, 2011 Share Posted September 11, 2011 Part #18 is not the crankshaft position sensor. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 11, 2011 I Donated Share Posted September 11, 2011 Yeah, #18 is the sprocket for the timing -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
collier89139 Posted September 11, 2011 Author Share Posted September 11, 2011 camshaft position sensor is up top and the cranshaft sensor is near the bottom I think Link to comment Share on other sites More sharing options...
Osei Posted September 11, 2011 Share Posted September 11, 2011 You are all correct, no excuses. here http://subarupartsforyou.com/cp_partdetail.php?partid=3080 O. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 11, 2011 I Donated Share Posted September 11, 2011 camshaft position sensor is up top and the cranshaft sensor is near the bottom I think No. Camshaft sensor is on the top of the driver side head behind the rear part of the timing cover Crankshaft is right above the crank pulley bolted to the block -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
