PearlBlueGT Posted September 8, 2011 Share Posted September 8, 2011 My mechanic said LGT doesn't have fuel filter except for sock that's inside the tank, is that true? Link to comment Share on other sites More sharing options...
.blackgt. Posted September 8, 2011 Share Posted September 8, 2011 I believe your mechanic is correct. I have heard of people installing an in-line filter. Link to comment Share on other sites More sharing options...
AShoe Posted September 9, 2011 Share Posted September 9, 2011 ^yup. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 9, 2011 Author Share Posted September 9, 2011 wow, how cheap can you get Subaru. First it's crappy banjo bolts that restrict oil flow and I had to have engine swapped out and now it's fuel filter. How many more surprises are there. I think only thing I like about our LGT is style and AWD (which was reason we got it in first place) If I knew how cheap they are built I'd probably buy CRV, etc. Link to comment Share on other sites More sharing options...
frank_ster Posted September 9, 2011 Share Posted September 9, 2011 well the banjo bolt filters are there for a reason.. and the sock is probably fine enough so it keeps out the shit that won't fit through the injectors. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
VermontGT Posted September 9, 2011 Share Posted September 9, 2011 Subaru is the only manufacturer using this design Link to comment Share on other sites More sharing options...
rao Posted September 9, 2011 Share Posted September 9, 2011 More proof that the Legacy is a piece of garbage Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Wrench Posted September 9, 2011 Share Posted September 9, 2011 Newer Honda's use this design too. Link to comment Share on other sites More sharing options...
rao Posted September 9, 2011 Share Posted September 9, 2011 OMGWTFBBQQQ!!!111!!11 Now Honda's suck too Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
frank_ster Posted September 9, 2011 Share Posted September 9, 2011 uh have any of you had a problem with a plugged injector ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
bmx045 Posted September 9, 2011 Share Posted September 9, 2011 Pearl, you're a troll. Everyone knows you hate your car and have absolutely no idea about anything automotive, seeing that you have ticking engine noise and think injector cleaner is going to resolve mechanical ticking. The sock filter, if you've ever seen it...which I doubt.....is actually pretty large and does a fine job. I haven't heard of any issues with debris in the fuel, EVER. Just because there isn't a can-like fuel filter doesn't mean it's garbage. You just have no idea how any of this works, so you jump to the conclusion that because it's a different design that it's far inferior to a god damned CRV Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 9, 2011 Author Share Posted September 9, 2011 Yes, there's sock inside fuel tank but it doesn't clean all of the stuff off, there's still minuscule particles that get past the sock and with time (let's say 94K like on my car) they plug up tiny injector holes. You should be more careful branding other people your own name. Link to comment Share on other sites More sharing options...
bmx045 Posted September 9, 2011 Share Posted September 9, 2011 ....and this is any different from other designs how? in line filters fail at high mileage too. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 9, 2011 Author Share Posted September 9, 2011 ....and this is any different from other designs how? in line filters fail at high mileage too. Yes, that's why you change it, but if your car doesn't have one then all the dirt collects inside your injectors and valves Link to comment Share on other sites More sharing options...
bmx045 Posted September 9, 2011 Share Posted September 9, 2011 The sock is a filter, that's why our cars don't have an in line. Frankly, you don't see many people posting about clogged injectors on this site...in fact I can't name one....and there are a lot of high mileage 05's on this site Link to comment Share on other sites More sharing options...
Nrw Posted September 9, 2011 Share Posted September 9, 2011 group buy in inline fuel filters?? Link to comment Share on other sites More sharing options...
bmx045 Posted September 9, 2011 Share Posted September 9, 2011 group buy of irish spring in your mouth Link to comment Share on other sites More sharing options...
SSpeed Posted September 9, 2011 Share Posted September 9, 2011 Subscribed as it has the potential to get exciting... Link to comment Share on other sites More sharing options...
Nrw Posted September 9, 2011 Share Posted September 9, 2011 group buy of irish spring in your mouth Link to comment Share on other sites More sharing options...
MrHellrais3R Posted September 9, 2011 Share Posted September 9, 2011 if you want to clean your injectors so bad then send them to witchhunter and pay the $25 to have it done. If you have no fuel problems then don't bother.. However since you have no evidence of any fuel issues other than speculation of a fuel problem causing ticking (......) then spend your money and find something else to blame for your ticking. Its your money and your car, do what you think in your limited opinion is right. FWIW the sock can be replaced too if thats such a huge problem for you as well. Gotta hate it when the sock in the tank causes engine ticks... happens all the time...... Link to comment Share on other sites More sharing options...
BigTDogg MA Posted September 9, 2011 Share Posted September 9, 2011 ....and this is any different from other designs how? in line filters fail at high mileage too. But at least you can change those every 30k miles or so. I have more comfort in an external filter design. Link to comment Share on other sites More sharing options...
theflystyle Posted September 9, 2011 Share Posted September 9, 2011 just so you guys know. my 94 legacy had an inline filter in the engine bay. was easy to replace but then again i couldnt really tell a difference after i changed it. theres gotta be a reason for the evolution Link to comment Share on other sites More sharing options...
