A bit of rebuilding
Hey guys, I've MIA from the forums for a while but the Legacy was redone with TD05-20G, FMIC, Methanol, etc and ran an open source tune and run like that for a while but was having some issues with it. I ended up blowing a ringland on the #2 cylinder so right now the motor is out and at the machine shop.
This is whats going in right now
100mm CP Pistons
Manley H-Beam rods
Nitride Cross Drilled Crank
ACL Race Bearings
ARP Studs
STI 11mm Oil Pump
Gates Racing Kevlar Timing Belt
Covert Oil Pickup
OEM Case Bolts
OEM Water Pump
OEM Tensioner
+1mm Custom Nitride Valves
BC Valve Springs and Ti Retainers
Ferrea Valve Seals
OEM Keepers
OEM Cams
Custom Oil Cooler
Also, the 20g is coming off and we are fabricating some piping for a rotated Holset HE351 :-D
There will probably be some more goodies that will go on
Here is what number 2 looked like after we pulled it out
http://img529.imageshack.us/img529/1038/cyl2.jpg
2005 Legacy GT 5MT
Buy my stuff Here
So I can build my 6.0L V8 Legacy GT Here
Good luck with your new build.
So, did you learn your lesson about open source tuning ?
Once you make that kind of changes, you need to get the car to a Professional tuner and a wideband O2 sensor on a dyno.
I'm sure one of us here can recommend someone local to you. If not call Brad at http://www.rlzengineering.com/ I'm sure he can send to someone with a AWD dyno.
Tell Brad the old guy from CT with the yellow hatch who had his D16z6 head sent you.
Engine Build - Click Here
100mm pistons are a mistake. Push it, and you'll split a sleeve. It's happened on every stock-sleeved, 100mm piston car I've known that's tried to push it for power.
Everything else can hold it... except the block.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
The car was tuned by a local tuner using open source on a dyno. The blowing up of the ringland was caused by some other factors that hapenned (bad gas and some leaks that caused it to lean out)
2005 Legacy GT 5MT
Buy my stuff Here
Learn your lesson on opensource? It is funny that my protuner had a wideband and a dyno and still managed to damage my vehicle. I have had 2 protunes and my e-tune from infamous is by far the best tune. My data logs are always clean as is my LV. Opensource has nothing to do with it. It is all about the tuner. I don't think we should be ragging on anyone. Just tell the OP sorry about the bad luck and hope your new build works out for you. :-)
did you use a wb02 for the infamous tune? if not then now you know why your lv's are so clean
I still believe in opensource tuning and know the issue was caused by an outside condition so I am sticking with it and trust the tuner.
I am having second thoughts now on the 100mm pistons and will do some more research but may have to go to another block since this one has already been bored
2005 Legacy GT 5MT
Buy my stuff Here
You could always sleeve the block.
