Tomkat1127 Posted August 8, 2011 Share Posted August 8, 2011 Pondering the vast array of exhaust's (mainly CBE's) for the LGT I notice two distinct methods of connection at the mid pipe to y-pipe and then again at the y-pipe to muffler connections. The connection type being either flange connections or slip-fit (clamped) connections. All the systems use a flange at the DP to mid-pipe. What is everybody's opinion and personnel experience (limited to Subaru) of the two styles? Is one really better then the other? Obviously, the flange connection requires a gasket and the slip fitting pipes require clamps (band or u-bolt). Borla, Magnaflow, and FMS use slip-fit connections. Is this to allow for minor length adjustments? Stromung (msprank version) and CNT is all flange connections. What is a guy supposed to do when a gasket burns/blows out? Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 8, 2011 Share Posted August 8, 2011 Flange/gasket much less likely to leak. If a gasket blows out, undo two bolts and put in a new one. It's not very complicated. Link to comment Share on other sites More sharing options...
SurlyOldManMN Posted August 8, 2011 Share Posted August 8, 2011 I'm not impressed with the connections on my magnaflow. It's almost impossible to keep them from leaking. Link to comment Share on other sites More sharing options...
Tomkat1127 Posted August 8, 2011 Author Share Posted August 8, 2011 If a gasket blows out, undo two bolts and put in a new one. It's not very complicated. Do they all use the same style/size gaskets? If not one may have trouble finding the correct replacement. Link to comment Share on other sites More sharing options...
SurlyOldManMN Posted August 8, 2011 Share Posted August 8, 2011 That's what RTV is for mang. Link to comment Share on other sites More sharing options...
Tomkat1127 Posted August 17, 2011 Author Share Posted August 17, 2011 Really....that's all the opinions this board has on a legit topic. Come on...I've seen better discussion on this board about much more trivial topics.... I knew I should have posted a dirty or funny picture, maybe then more would have looked..... Link to comment Share on other sites More sharing options...
Nrw Posted August 17, 2011 Share Posted August 17, 2011 I prefer slip fits. My magnaflow seals just fine :shrug: Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 17, 2011 Share Posted August 17, 2011 Do they all use the same style/size gaskets? If not one may have trouble finding the correct replacement. I wouldn't be too concerned. Between auto stores, dealerships, and forum vendors, you will be able to find the gasket that you need. Blow outs are not very common. Link to comment Share on other sites More sharing options...
stclark13 Posted August 18, 2011 Share Posted August 18, 2011 i've had both and never had a problem with either. I actually found the slip joints on the magnaflow easier to adjust to get a even fitment on both sides. Lets just say i wouldn't let it be the reason i didnt buy a certain exhaust. Link to comment Share on other sites More sharing options...
IMPORTIMAGE Posted August 18, 2011 Share Posted August 18, 2011 it really depends on the maker of the exhaust and fitment. the slip joints do work well and allow for great fitment. the flange style when made properly works great too...it really just depends on the exhaust, what your expecting out of it, and the budget. 1-941-257-9618 http://www.importimageracing.com Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 18, 2011 Share Posted August 18, 2011 Flanges. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Strizzy Posted August 18, 2011 Share Posted August 18, 2011 Flange (though my Perrin is v-band at the mid/y connection). 2-bolt 3" and 2.5" gaskets are pretty much all universal and are cheap as hell to buy. I get mine for a buck a piece at the local CarQuest. I've had a few slip-fit exhaust on other vehicles over the years, and they usually have a small leak at the joint, or become a pain in the as$ to remove from over tightening to stop the leaks. My bad luck build Link to comment Share on other sites More sharing options...
Aken Posted August 18, 2011 Share Posted August 18, 2011 Is there a high-temp hose, similar to silicone hoses that connect intake parts in the engine bay, that you could use to help with leaks at slip joints? Link to comment Share on other sites More sharing options...
Tomkat1127 Posted August 19, 2011 Author Share Posted August 19, 2011 Ok guys. Thanks for the comments. My experience is the same as most of what I am hearing here. Slip fits are ok if the pipes are a tight fit and clamped very hard. All my past exhausts were custom muffler shop jobs on non-subaru vehicles. They were slip fits leaving the factory manifold to intemediate pipe flanged. Even with galvanized pipes the clamps would rust off and pipes rusted out at any wells. Most Subaru vehicle systems are SS so that is not a concern. If i really like a system and it is slip fit, then so be it. My preference will be for a flanged system. Link to comment Share on other sites More sharing options...
