devilmademedoit Posted August 6, 2011 Share Posted August 6, 2011 I have a question on the compression techniques on the 98' and up belt tensioners. When I put my jdm motor in my legacy, I swapped over parts that were on my old motor. The timing components being one of them due to the fact that they only had about 10k on them, but used a new belt so I could see the marks on it and they are cheap enough. The tensioner I compressed in my vise that is mounted on my bench not a vertical press. Was this a bad idea? Link to comment Share on other sites More sharing options...
johnegg Posted August 6, 2011 Share Posted August 6, 2011 i think it is only bad, if you compressed it too fast. you can blow out the seals if you do it too fast. i have never heard of anyone damaging a tensioner by doing it horizontally. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 6, 2011 I Donated Share Posted August 6, 2011 I think its a bad idea to re use tensioners....period -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Osei Posted August 7, 2011 Share Posted August 7, 2011 I think its a bad idea to re use tensioners....period The old style tensioners very rarely go bad. Check with anyone who regularly does Suby engines. The newer 2 piece style should be done at the same time interval as the t belt, every 105K. Not because of any known problem, but the question is will they last another 100K as they have a built in idler roller. The vertical method to compress is to keep the air at the top of the cylinder. Subaru revised it's technique during the 2nd gen time. I just use a c clamp and hang it on a door knob between turns. O. Link to comment Share on other sites More sharing options...
