kanders2 Posted August 6, 2011 Share Posted August 6, 2011 My friend has a 2005 legacy 2.5i that has thrown a rod. The car is bone stock. should he A) get a rebuilt engine (quoted $4k plus labor) B) get a new engine (quoted $6k plus labor) C) buy a used built up turbo motor and put it in D) get a new car and cut all losses how do those quoted prices sound? how much would it cost to buy a built turbo motor and put that in his car? Link to comment Share on other sites More sharing options...
Kodax Posted August 6, 2011 Share Posted August 6, 2011 I believe the quote price seems a bit high. I read some people on the forum who did it for less. Not sure though, my memory might be fuzzy. Link to comment Share on other sites More sharing options...
frank_ster Posted August 6, 2011 Share Posted August 6, 2011 option E) buick swap 1K + labour Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted August 6, 2011 Share Posted August 6, 2011 option E) buick swap 1K + labour And the skill to do it, PRICELESS Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 6, 2011 Share Posted August 6, 2011 and the skill to do it, priceless Mike ^+ 1 Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 6, 2011 Share Posted August 6, 2011 B and C are definitely out. Both are stupid. $4k to rebuild sounds about right with a brand new short block and all the gaskets and labor and stuff. Maybe a smidge high, but not astronomical. So, IMO, I'd either rebuild the engine or try to get rid of it. What do you mean "thrown rod"? Like it's sticking out of the block? Or it just makes a lot of noise? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2011 Share Posted August 6, 2011 ^ I'm with him that sounds about right. Think of all the things that have to happen to rebuild or replace a short block. There are a ton of nickle and dime things that add up fast. The timing belt kit is is $300. Fluids if they r7r the tranny fluid might as well as long as your there, $100 + Do you need a clutch ? $600 there Do a google search for a 2.5i short block. I also agree with HAMMER DOWN, that is priceless. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted August 6, 2011 Share Posted August 6, 2011 An NA used engine (EJ253) should be fairly easy to find. Do not buy one unless you hear it run! You'll never find an EJ255 or 257 used for less than $4-6K. Link to comment Share on other sites More sharing options...
Squiden Posted August 6, 2011 Share Posted August 6, 2011 I agree that sounds really high - I got my new, fully built STI motor with everything including install for 7k. Link to comment Share on other sites More sharing options...
turbodog Posted August 6, 2011 Share Posted August 6, 2011 IMHO, drop in a used motor or swap to any sort of turbo motor. The NA swap should be under $3k for a used motor and labor, at a shop. They really aren't hard to do - anyone with a garage, rented engine hoist, decent tools, service manual and a friend with skills should be able to handle it in a weekend or so. The trick is to get a good running motor that is mostly a drop in at a reasonable price. Swapping to a turbo motor is much more involved and has a huge price range. Could be anywhere from as cheap as a $1-2k (?) wrx EJ205, to a $8-10k full sti clip swap with 6 speed, brembos, etc - plus labor & misc parts. All options are going to require a new cross member and re-wiring the car. Link to comment Share on other sites More sharing options...
