northboundtrain Posted June 8, 2005 Share Posted June 8, 2005 Hello to everyone, I'm getting ready to replace the clutch on my wife's '94 Legacy. I've done a few clutch jobs, but I've never worked on a Subaru before. Any advice regarding the particulars of this job would be greatly appreciated. In addition to replacing the clutch, I was planning on having the flywheel turned and replacing any seals I can get to easily. Anything else I should do? Are the flywheel bolts a one-time-use item, or can they be reused? Thanks Link to comment Share on other sites More sharing options...
melayout Posted June 8, 2005 Share Posted June 8, 2005 Timing belt, water pump, the usual for an interference motor ? I keed I keeed Link to comment Share on other sites More sharing options...
agctr Posted June 8, 2005 Share Posted June 8, 2005 G'Day and Welcome to the Forum..... Do you have a copy of the Original Owner's Manual. I would have a look at this and see what it states. Not one to get my hands dirty as I leave that up to the Dealership BUT Im sure they wouldnt mind pointing u in the right direction if you get stuck with the new install. All the best. Ada///M. Link to comment Share on other sites More sharing options...
rao Posted June 8, 2005 Share Posted June 8, 2005 Make sure you have drift punches to remove the roll pins from the front axles. Otherwise it is pretty typical. People do re-use the flywheel bolts, but they are cheap enough to replace and make sure you use a new throw out bearing. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
