cobb Posted July 31, 2011 Share Posted July 31, 2011 :confused:Just like the title says my idle will level off at about 1100rpm after revving it to any rpm and then it slowly drops back to normal 7000 or so rpm, any ideas as to what is causing this? Link to comment Share on other sites More sharing options...
frank_ster Posted July 31, 2011 Share Posted July 31, 2011 how slow ? vaccume leaks ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
cobb Posted July 31, 2011 Author Share Posted July 31, 2011 no leaks that i can see, engine is still smooth just has a very slow dropping idle like maybe from 1100 you can count four to five seconds Link to comment Share on other sites More sharing options...
Max Capacity Posted July 31, 2011 Share Posted July 31, 2011 Just be glad you have this problem and not the other way around. I believe my 09 Spec B likes to wait a second or two at around a 1000 before settling out at idle. You may have a sensor dirty You may want to edit that 7000 to 700 too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cobb Posted July 31, 2011 Author Share Posted July 31, 2011 lol yeah 700 Link to comment Share on other sites More sharing options...
Conor Posted July 31, 2011 Share Posted July 31, 2011 You might be running a little lean, that's a common symptom for that. I'd try cleaning off your MAF sensor first, worth a shot. Link to comment Share on other sites More sharing options...
cobb Posted August 1, 2011 Author Share Posted August 1, 2011 Sounds plausible, I'll defiantly try it out tomorrow after work and let ya know how it goes. Any specific brand you recommend? Link to comment Share on other sites More sharing options...
Conor Posted August 1, 2011 Share Posted August 1, 2011 No, any MAF sensor cleaner will be fine. The one I have is made by CRC, but I've never heard of anybody preferring one brand over another. You can also use non-chlorinated brake cleaner or electrical contact cleaner if you can't find any MAF cleaner. Shouldn't be too hard to find, though. Link to comment Share on other sites More sharing options...
Rushin Posted August 1, 2011 Share Posted August 1, 2011 Does it do it when you are in gear with the clutch in or just standing still and rev it up? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 1, 2011 Share Posted August 1, 2011 I watched my tach today while driving. 09 Spec B, let off the gas to coast to a stop sign. Idle dropped to 1100, stayed there until the car stopped moving then dropped to 800-900. I even rev'd it while still rolling, did the samething. At the stop sign, rev'd it, it came back to 900. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rushin Posted August 2, 2011 Share Posted August 2, 2011 Try doing the same without the clutch in and in neutral. Link to comment Share on other sites More sharing options...
cobb Posted August 2, 2011 Author Share Posted August 2, 2011 Mines a 5eat so I did it while in neutral, I had just re set the ecu with my AP and it's not doing it anymore so maybe I had something glitching, I did however use some mad cleaner and now it just runs slot sm Link to comment Share on other sites More sharing options...
cobb Posted August 2, 2011 Author Share Posted August 2, 2011 Runs alot smoother* damn iPhone lol Link to comment Share on other sites More sharing options...
cobb Posted August 2, 2011 Author Share Posted August 2, 2011 Maf* Link to comment Share on other sites More sharing options...
MasAyinde Posted August 2, 2011 Share Posted August 2, 2011 Before I opened this thread and thought to myself "Shouldn't Cobb know how to fix seemingly simple issues?" Link to comment Share on other sites More sharing options...
Conor Posted August 3, 2011 Share Posted August 3, 2011 Glad to hear that the reset helped. Cleaning the MAF usually makes things more pleasant with little effort and can help a lot of idling and low RPM issues. Link to comment Share on other sites More sharing options...
