CMFR230 Posted July 29, 2011 Share Posted July 29, 2011 I just got a 2006 Legacy GT with the 2.5 Spec B boxer motor.. It runs fine just cruising but then in third gear when i get on it it hesitates and is almost like its governed at 3rpms and wont move and it does the same in fourth and fifth. i cant get the car to go above 80mph.. anyone know anything about this? Link to comment Share on other sites More sharing options...
W1CKED Posted July 29, 2011 Share Posted July 29, 2011 http://luckybob.smugmug.com/Cars/LegacyGT-Related/i-6hnDjB6/0/O/noob-small.png So...you have an '06 spec.B, or you have an '06 GT? Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 06gt Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2011 Share Posted July 29, 2011 what tranny 5speed or automatic ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 5spd Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 I just dont understand what would stop the engine from holding out... Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 29, 2011 Share Posted July 29, 2011 I just dont understand what would stop the engine from holding out... Think of an engine like a woman...they don't make any sense and they hold out all the time Link to comment Share on other sites More sharing options...
Scooter Posted July 29, 2011 Share Posted July 29, 2011 IN order for the experts here to help, you're probably going to need to buy a $15 VAG-COM cable, do some datalogging, and post the logs here. Some searching will on the site here will let you learn how to do that. Here's one link: http://legacygt.com/forums/showthread.php/using-ebay-vag-com-cable-datalog-96737.html Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 29, 2011 Share Posted July 29, 2011 What country are you from CMFR230? Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 i heard maybe the cat is clogged and may need a new one with an o2 sensor, it the MAF senor is going out? do any of these sounds like it could be a problem to solve the issue. and im from the US. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 29, 2011 Share Posted July 29, 2011 I dont think its a clogged cat. How many miles? AT or MT? Describe the problem in more detail. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted July 29, 2011 Share Posted July 29, 2011 The car would run worse than it is if it were a clogged cat. It's most likely a vacuum leak. Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 its manual, first gear is alright, second gear is ok, third gear it sputters and sometimes wont go above 3grand and it just holds and it smells like its burning something. and when cruising in 5th gear it stable untill i hit the gas i cant get it to go above 70-80 mph it just spits and sputters. Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 and its at 106,000 Link to comment Share on other sites More sharing options...
ShadowImg Posted July 29, 2011 Share Posted July 29, 2011 It actually sounds like for some reason your car has a valet mode map applied to it. You definitely need to get it datalogged and check knock corrections, etc. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 29, 2011 Share Posted July 29, 2011 Any mods? Can you go above 3k in 1st or 2nd? Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 no mods its stock, i can go above 3 in first and second but then 3-5 it just holds like its red limiting. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted July 29, 2011 Share Posted July 29, 2011 It's most likely a vacuum leak. Link to comment Share on other sites More sharing options...
ehsnils Posted July 29, 2011 Share Posted July 29, 2011 Everyone - can you please refrain from stupid comments about Spec B or not everytime it comes up? Link to comment Share on other sites More sharing options...
ehsnils Posted July 29, 2011 Share Posted July 29, 2011 As for the engine problem - I agree that it can be a vacuum leak, but it can also be the fuel pump that's unable to keep up. Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 so thats all it could be is a vacuum leak? why can i hit it up in first and second but third it drowns out to fifth gear? Link to comment Share on other sites More sharing options...
CTATV Posted July 29, 2011 Share Posted July 29, 2011 Everyone - can you please refrain from stupid comments about Spec B or not everytime it comes up? so it wasnt at all relevant when the OP said they had an 06 GT with a Spec.B motor in it English Second Language failure here twice it seems... Link to comment Share on other sites More sharing options...
CMFR230 Posted July 29, 2011 Author Share Posted July 29, 2011 So it doesnt have anything to do with the turbo or anything? the car idles fine it runs good at normal drive i can punch it in first and second somewaht of a hesitant in second, but third it jumps and sputters does the same in fourth and fifth gear. Link to comment Share on other sites More sharing options...
CTATV Posted July 29, 2011 Share Posted July 29, 2011 oh it could def have to do with the turbo. Or not. You should data log like others said Link to comment Share on other sites More sharing options...
ShadowImg Posted July 29, 2011 Share Posted July 29, 2011 I had a vac(boost) leak that only happened under load (took pressure to make it leak), which manifested at the same time as yours, but the car still drove fine, it was VERY noisy when you hit 3k in 3rd while pushing it. That's more what I'd expect from a boost leak sort of situation. I think you'd notice the noises/etc if that were the case. It would take a very significant leak to make it so you can't accel past 3k. Link to comment Share on other sites More sharing options...
