Tehnation Posted July 29, 2011 Share Posted July 29, 2011 Anyone have a good explanation of how a stock 5mt clutch is supposed to feel and when it grabs. Seems I have to pin to floor to shift properly and is heavy. First time owning/driving one. Bought it used so I have no real reference. Link to comment Share on other sites More sharing options...
goneskiian Posted July 29, 2011 Share Posted July 29, 2011 Sounds pretty normal. How many miles on it? Link to comment Share on other sites More sharing options...
Tehnation Posted July 29, 2011 Author Share Posted July 29, 2011 Seems normal was exactly what I wanted to hear. Car has 95k. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2011 Share Posted July 29, 2011 Yep, these things like you use the full swing of the clutch pedal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 29, 2011 Author Share Posted July 29, 2011 Thats what i'm realizing, been a while since I owned a stick, wanted to make sure! Thanks a bunch guys! Link to comment Share on other sites More sharing options...
goneskiian Posted July 30, 2011 Share Posted July 30, 2011 95K is quite a few miles on a stock clutch. If it is indeed the original. Folks have had them last longer though. Link to comment Share on other sites More sharing options...
iNVAR Posted July 30, 2011 Share Posted July 30, 2011 My clutch was low and stiff when I got it at 37K miles. I think the engagement point continued to move lower until it was practically only 1" off the ground. At about 53K I went to stage 2, and the clutch started slipping a few hundred miles later. I replaced it with an ACT clutch and PP and WRX single mass flywheel. Engagement point moved up. But stiffness remains. So, dunno if the clutch being that low means anything but maybe be prepared to replace it should it start slipping... Might be a sign? Link to comment Share on other sites More sharing options...
Zac88 Posted August 7, 2011 Share Posted August 7, 2011 at 145,000km on my stock clutch, stiff and engages pretty low too, sign that it needs replacement? Link to comment Share on other sites More sharing options...
__raj Posted August 7, 2011 Share Posted August 7, 2011 We just replaced ours with a stock clutch(115k) and it feels significantly easier to push. I thought I was getting old and tired of driving a manual transmission. However a clutch replacement I love it once again. Our throw out bearing was fully seized though. Link to comment Share on other sites More sharing options...
