1-3-2-4 Posted July 25, 2011 Share Posted July 25, 2011 If someone could help me out on this it would be great.. so while I'm waiting for my timing belt kit to come in along with some gaskets I need to replace the headgaskets on the wagon.. I need to check the valve clearance.. I picked up a vernier micrometer yesterday.. Ok so I understand how to figure out the replacement size somewhat.. I check with my feeler gauge add that with the current shim size and I get the replacement size that brings me back into spec? a 0.0001" mic sounds pretty excessive for valve clearances Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 26, 2011 Share Posted July 26, 2011 Did they take off much material when you had it decked? If not you should go with the OEM gasket thickness. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 26, 2011 Author Share Posted July 26, 2011 never had the heads milled yet nor have I checked for warppage yet. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 26, 2011 Share Posted July 26, 2011 Well before you spend a lot of time calculating the HG thickness you might want to ensure it wont all be meaningless by warped mating surfaces. I have seen a many "simple rebuilds" go sour a few hundred miles after due to a failed HG in which the surfaces were not checked. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 26, 2011 Author Share Posted July 26, 2011 Yeah I understand.. I have to pull the motor first to check all that it would be crazy not to check that before doing the gaskets.. but my main concern is the shims for the valves Link to comment Share on other sites More sharing options...
SBT Posted July 26, 2011 Share Posted July 26, 2011 Figure out what needs to be done with the head (decked and trued and HG thickness required) and then worry about the valves. 1 follows the other. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SSpeed Posted July 26, 2011 Share Posted July 26, 2011 When I had the heads refreshed, the machine shop took care of the shims for me... I would think any good machine shop is going to do that... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 27, 2011 Share Posted July 27, 2011 Are getting rebuilt heads with new cams ? If so you wont need to adjust lash until things break in a bit. Link to comment Share on other sites More sharing options...
SSpeed Posted July 27, 2011 Share Posted July 27, 2011 ^^ You need to check valve clearance on those shims on a fairly regular basis for the EJ25D... Replacing the headgaskets I'd hope he gets the head refreshed... at the very least make sure you keep the shims in order and put them back where they came from.. Link to comment Share on other sites More sharing options...
