Facman Posted July 23, 2011 Share Posted July 23, 2011 Hello, just joined and hoping the group can help me with this. I bought my first Subaru Legacy Brighton about 6 months ago and shortly after buying it the CEL would come on and the engine would turn over and not start, this usually goes on for about 10 minutes then the car will start. If the CEL is not the engine starts without a problem. So I procrastinated on getting this fixed until this week when on holidays of course and the car refused to start so it was a tow home and renting a car. Thinking that the problem has come to a point where a part must be changed I came home turned over the engine and it started right away. I have not checked for codes hoping that this may be a problem with these cars and someone can point me in the right direction. Any suggestions greatly appreciated. Frank Link to comment Share on other sites More sharing options...
Zues Marine Posted July 23, 2011 Share Posted July 23, 2011 that code will pinpoint your problem, use an obdii reader that o'reillys/autozone/shucks/ napa lets you use, theyll try to tell you its not obdii and youll tell them to fuk themselves..pull the code, the ecu should shill have the code in it even when the light isnt on, post back here for solutions Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 23, 2011 I Donated Share Posted July 23, 2011 nobody can help you unless you pull your codes. it can literally be ANYTHING. The check engine light means something is wrong. Maybe you should have fixed it instead of ignored it -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Facman Posted July 26, 2011 Author Share Posted July 26, 2011 OK, so I had someone pull the code and it read P0340 CMP Sensor, A Circuit Bank 1 Can somone tell me what this code is and how detailed the repair is? Thanks, Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 26, 2011 I Donated Share Posted July 26, 2011 its the crankshaft position sensor. not a hard fix. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Facman Posted July 26, 2011 Author Share Posted July 26, 2011 Thanks for the info and your quick response Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 26, 2011 I Donated Share Posted July 26, 2011 no problem....except its not crankshaft. Its Camshaft.sorry about the typo -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
johnegg Posted July 27, 2011 Share Posted July 27, 2011 http://www.obd-codes.com/p0340 Link to comment Share on other sites More sharing options...
