Jmhm17 Posted November 29, 2011 Share Posted November 29, 2011 hmm i may consider now that im out of warente.. i still have the LGT header i bought of shtbxr over a year ago in my basment.. the only issue is no one can tune my car. its been a while since i talked to brentunning but i cant see him getting definitions for a 2.5i Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 30, 2011 Author Share Posted November 30, 2011 hmm i may consider now that im out of warente.. i still have the LGT header i bought of shtbxr over a year ago in my basment.. the only issue is no one can tune my car. its been a while since i talked to brentunning but i cant see him getting definitions for a 2.5i tactrix 2.0 cable and you nearest reputable tuner will get you fixed up plenty if 2.5is have been tuned. Link to comment Share on other sites More sharing options...
06legacy2.5 Posted December 5, 2011 Share Posted December 5, 2011 so headers for an older impreza rs will fit up to a 06 legacy 2.5i with the exception of the re-routing, correct? what about o2 sensor wire extensions? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 5, 2011 Author Share Posted December 5, 2011 so headers for an older impreza rs will fit up to a 06 legacy 2.5i with the exception of the re-routing, correct? what about o2 sensor wire extensions? They will fit but with http://www.Rallisportracing.com making bolt on headers for the 06-09 2.5i there is no need to deal with all that Link to comment Share on other sites More sharing options...
09anderson Posted June 12, 2012 Share Posted June 12, 2012 Is it possible to not cut the header and make an extension of the cbe to meet the spot for the uppipe? Sent from my DROID BIONIC using Tapatalk 2 Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 13, 2012 Author Share Posted June 13, 2012 Is it possible to not cut the header and make an extension of the cbe to meet the spot for the uppipe? Sent from my DROID BIONIC using Tapatalk 2 Hey there, so first off are you planning to turbo your 2.5i ? I imagine you aren't at the level yet so you may be confused slightly, or do you have a turbo kit on your car? In stock form we dont have an up pipe but we have a mid-pipe which terminates at the same point as a Turbo Legacy's lower section down pipe (06-09). Our mid pipe/cat-pipe is fairly free flowing but if you are looking to free up flow you could simply have a straight pipe built to replace it. Link to comment Share on other sites More sharing options...
09anderson Posted June 13, 2012 Share Posted June 13, 2012 I pm'd you.. I was in the wrong thread,i thought it was your header thread Link to comment Share on other sites More sharing options...
jhow257415 Posted July 3, 2012 Share Posted July 3, 2012 So this is the the OEM manifold-cat (UEL) from a 2005 Legacy 2.5i! I have an 07' with a newer (EL) version that has a 2 inch hairline crack in the flexion area (flex piping/ accordion section). Does anyone know if I can buy this 2005 part and install onto (direct bolt on) my 2007? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 3, 2012 Author Share Posted July 3, 2012 So this is the the OEM manifold-cat (UEL) from a 2005 Legacy 2.5i! I have an 07' with a newer (EL) version that has a 2 inch hairline crack in the flexion area (flex piping/ accordion section). Does anyone know if I can buy this 2005 part and install onto (direct bolt on) my 2007? No, that is a stock 06+ N/A manifold, more specifically my 2008 Legacy 2.5i The cheapest place to score one is in NASIOC or RS25.com as those impreza guys tend to run more UEL setup and ditch their stock parts Link to comment Share on other sites More sharing options...
jhow257415 Posted July 3, 2012 Share Posted July 3, 2012 Oh cool, that's ur manifold! Kinda ironic, caption from ur picture (the source that I found) called them the 05 manifold, that doesn't sound correct based on ur findings, so will the 05 (whatever it looks like) bolt right up to the 07? BTW, Thanks Gee-Otto for the help! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 3, 2012 Author Share Posted July 3, 2012 Oh cool, that's ur manifold! Kinda ironic, caption from ur picture (the source that I found) called them the 05 manifold, that doesn't sound correct based on ur findings, so will the 05 (whatever it looks like) bolt right up to the 07? BTW, Thanks Gee-Otto for the help! No it wont bolt up to your car, you need 06-09 Non Turbo stock exhaust manifold like the one you had pictured Link to comment Share on other sites More sharing options...
jhow257415 Posted July 3, 2012 Share Posted July 3, 2012 Gotcha, thanks!!! Link to comment Share on other sites More sharing options...
kevinlman Posted September 17, 2012 Share Posted September 17, 2012 Hi thanks to mr gee-otto and a few others here on this forum he's given me motivation to do the UEL header as well. http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5726.jpg http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5718.jpg http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5723.jpg http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5720.jpg http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5738.jpg http://i56.photobucket.com/albums/g167/hothotkevin/Exhaust%20Legacy/IMG_5736.jpg Thanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 17, 2012 Author Share Posted September 17, 2012 Sound clip(s) Link to comment Share on other sites More sharing options...
kevinlman Posted September 23, 2012 Share Posted September 23, 2012 ok I give up on trying to embed the video http://www.youtube.com/watch?v=6yMBs...ature=youtu.be Link to comment Share on other sites More sharing options...
kevinlman Posted September 23, 2012 Share Posted September 23, 2012 oops Link to comment Share on other sites More sharing options...
