cuylerjr Posted July 4, 2011 Share Posted July 4, 2011 I have an 05 Legacy 2.5i and am looking for some new brakes for it. I was wondering if 05 Legacy GT parts fit on my 2.5i? Link to comment Share on other sites More sharing options...
N.sane Posted July 5, 2011 Share Posted July 5, 2011 LGT brakes and 2.5i brakes are different. Are you planning on replacing with 2.5i parts or a swap to the LGT brakes? Link to comment Share on other sites More sharing options...
cuylerjr Posted July 5, 2011 Author Share Posted July 5, 2011 I want to swap to LGT brakes. Is it easy to do? Link to comment Share on other sites More sharing options...
Osei Posted July 5, 2011 Share Posted July 5, 2011 read sticky etc in brake forum. Use search. O. Link to comment Share on other sites More sharing options...
N.sane Posted July 5, 2011 Share Posted July 5, 2011 You will need: - LGT calipers - LGT caliper brackets (usually attached to the caliper already) - LGT brakes lines (usually attached also) - LGT rotors - LGT brake pads Everything is bolt-on. However, you might have to bend the dust plate back a little bit to prevent it from scratching the larger rotors. It happened in one corner after I swapped them onto my car. You may also need 17" wheels to clear the front brakes. Link to comment Share on other sites More sharing options...
cuylerjr Posted July 6, 2011 Author Share Posted July 6, 2011 Alright. Would they work with 18'' Wheels? And where would I be able to buy brand new calipers? Link to comment Share on other sites More sharing options...
N.sane Posted July 6, 2011 Share Posted July 6, 2011 Yea, I meant to say you need at least 17" wheels, so 18" wheels are fine. You can buy new calipers from the stealership or maybe rockauto.com. I got mine used. You may come across them in the Members Classifieds from time to time. Link to comment Share on other sites More sharing options...
