raloi Posted July 4, 2011 Share Posted July 4, 2011 I'm assuming I can put 18" Spec B wheels on my '05 L GT Limited with no problems ???? Always thought the stock 17" wheels on my car looked ... well, a little "small" ..... Link to comment Share on other sites More sharing options...
king_j Posted July 4, 2011 Share Posted July 4, 2011 yes Link to comment Share on other sites More sharing options...
Max Capacity Posted July 4, 2011 Share Posted July 4, 2011 Yes. I plan to put my 17" wheels with snow tires on them from my 05 GT on my 09 SpecB this winter. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Blameless Posted July 5, 2011 Share Posted July 5, 2011 18" on leggys look ace! my favourite upgrade so far... bar mine is not the std 18... they are super light rays wheels and made a noticeable difference all round... Link to comment Share on other sites More sharing options...
Drift Motion Posted July 5, 2011 Share Posted July 5, 2011 I dont see why not? I've had 17, 18, and 19 make sure the tire is the right size for LGT, not for SpecB Link to comment Share on other sites More sharing options...
BigBlack-V Posted July 5, 2011 Share Posted July 5, 2011 I hav 17x.5 bbs wheels on my spec.B with a rotora bbk kit but yes 18's will fit I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
ouch1011 Posted July 5, 2011 Share Posted July 5, 2011 Honestly, the tire size (or wheel offset, if you were using non OE wheels) has more to do with fitment problems than the wheel size. If you run the same size tires as the spec b runs (whatever that is) you should be ok. Link to comment Share on other sites More sharing options...
gyung Posted July 6, 2011 Share Posted July 6, 2011 I just went with 19s (offset of course), some 225s and called it good. They're big, but give the car a nasty stance and look beautiful Link to comment Share on other sites More sharing options...
raloi Posted July 6, 2011 Author Share Posted July 6, 2011 Thanks for the great info .... so what size (or dimensions, I guess) in 18" wheels would I look for ?? thx again -R Link to comment Share on other sites More sharing options...
goneskiian Posted July 6, 2011 Share Posted July 6, 2011 All you need to know... http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html Link to comment Share on other sites More sharing options...
raloi Posted July 6, 2011 Author Share Posted July 6, 2011 Awesome link .. thanks goneskiian Link to comment Share on other sites More sharing options...
