leg5spd Posted June 20, 2011 Share Posted June 20, 2011 does anyone have any tips/ recommendations when replacing idler pulley? Link to comment Share on other sites More sharing options...
WESTcoast Posted June 20, 2011 Share Posted June 20, 2011 as in timing belt idler pulley i take it? Link to comment Share on other sites More sharing options...
leg5spd Posted June 20, 2011 Author Share Posted June 20, 2011 yeah Link to comment Share on other sites More sharing options...
WESTcoast Posted June 20, 2011 Share Posted June 20, 2011 Should be quite easy, i think its a 12mm, and go at it. use a breaker bar is needed to loosen it. My friend did mine a long time ago, thing is i didnt help just watched(broken arm at the time) Link to comment Share on other sites More sharing options...
johnegg Posted June 20, 2011 Share Posted June 20, 2011 do you mean the crank pulley? also known as the harmonic balancer. do a search, there is plenty of info on how to. this has a lot of good info: http://legacygt.com/forums/showthread.php/check-timing-belt-95-legacy-outback-149733.html?t=149733&highlight=screwdriver+flexplate Link to comment Share on other sites More sharing options...
johnegg Posted June 20, 2011 Share Posted June 20, 2011 also post 46 in this thread http://www.ultimatesubaru.org/forum/showthread.php?p=993364#post993364 Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 21, 2011 I Donated Share Posted June 21, 2011 the idler pulley for the timing? Have you ever done a timing belt before? If you're asking for internet instructions for Subaru timing, maybe you shouldn't mess with it. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
GTTuner Posted June 21, 2011 Share Posted June 21, 2011 Tip: Never cook bacon in the nude. Link to comment Share on other sites More sharing options...
Baddog Posted June 21, 2011 Share Posted June 21, 2011 the idler pulley for the timing? Have you ever done a timing belt before? If you're asking for internet instructions for Subaru timing, maybe you shouldn't mess with it. Everyone has to learn. Period. Link to comment Share on other sites More sharing options...
leg5spd Posted June 21, 2011 Author Share Posted June 21, 2011 Now that ive given it a go, i realized i need a breaker bar... those bolts are definitely tight and it would be beneficial if i could figure out how to take out the drivers side radiator fan to have a bit more room to work Link to comment Share on other sites More sharing options...
Osei Posted June 21, 2011 Share Posted June 21, 2011 if the 95 are like the 97 they are in a cage that have to be removed as a unit. Make sure you line up the timing marks on crank and heads before you remove the belt. It will make life a lot easier when installing the new one. As long as you're not using a ratchet, a pipe over whatever you have will give the leverage you need. If you have to buy a breaker bar, get a 1/2 in. It'll give you more long term use. Even then I use a pipe over the handle. Less work. A torque wrench set to the highest setting would work too. For future ref. http://www.main.experiencetherave.com/subaru_manual_scans/ O. Link to comment Share on other sites More sharing options...
leg5spd Posted June 24, 2011 Author Share Posted June 24, 2011 all done! once i had the tools it wasn't bad Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 24, 2011 I Donated Share Posted June 24, 2011 Tip: Never cook bacon in the nude. grease splatters on the balls has to be painful edit - to keep this fair to women - grease splatters on the nipples must be painful! are there actually any women on this site? lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
