Baddog Posted June 15, 2011 Share Posted June 15, 2011 Lately I have been having this problem of power issues. It's like power spikes. In the low revs off the line it scoots along and pulls but then when I hit 2500 or so it feels like it dips in power then picks back up and then around 3k it goes back down. It also does this around 4000-5200 RPMs it just feels like it hits a brick wall. When I reset the ECU it goes away but eventually comes back. I should try to replace my plugs and wire soon. Just did my air filter. Any suggestions as to why this is even happening? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 15, 2011 Share Posted June 15, 2011 maf Link to comment Share on other sites More sharing options...
Baddog Posted June 15, 2011 Author Share Posted June 15, 2011 I have cleaned it as well. No change. Why would the MAF do this? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 15, 2011 Share Posted June 15, 2011 it could be bad altogether, sending the wrong readings and confusing the shit out of the ecu and what not, your problem sounds very similar to the one i had in november/december, which was a bad MAF Link to comment Share on other sites More sharing options...
Baddog Posted June 15, 2011 Author Share Posted June 15, 2011 Idles great though. But I guess I may have to give it a shot on a used one or something. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 15, 2011 Share Posted June 15, 2011 round here the yards have em for like $5, if maf isnt it, at least you have a backup if you ever need one Link to comment Share on other sites More sharing options...
subikid90 Posted June 15, 2011 Share Posted June 15, 2011 Maybe a bad fuel filter or fuel pump on its way out? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 15, 2011 I Donated Share Posted June 15, 2011 Do you have a cone filter? MAF oscolation or w/e its called? put the stock airbox / filter back on if you have it and see if that helps you out -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
