jayjay Posted June 5, 2011 Share Posted June 5, 2011 I am in need of new brakes for my bk gt wagon and was wondering which brake setup would be better. Would swapping out the front brakes for wrx brakes upfront and leave the stock brakes in back or am i better off getting replacement legacy crossed drilled & slotted rotors with hawk pads for the front & rear? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 5, 2011 I Donated Share Posted June 5, 2011 cross drilled and slotted rotors are pointless pretty much unless you are on a VERY high horsepower application. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
jayjay Posted June 5, 2011 Author Share Posted June 5, 2011 so just putting wrx calipers & rotors up front would be better than putting cross drilled and slotted all around? Link to comment Share on other sites More sharing options...
camroncamera Posted June 5, 2011 Share Posted June 5, 2011 2002 WRX fronts and 2000 Legacy rears ("H6" rear brake upgrade): http://legacygt.com/forums/showthread.php/2nd-gen-lgt-brake-upgrades-wrx-front-and-h6-rear-154702.html Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 5, 2011 I Donated Share Posted June 5, 2011 drilled and slotted rotors will not give you any sort of upgrade on stock brakes. Drilled and slotted rotors help combat brake fade, and on stock brakes and stock power, brake fade isn't really an issue. You would be waisting money. If you want better brakes, do WRX brakes in the front and H6 brakes in the rear -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
jayjay Posted June 6, 2011 Author Share Posted June 6, 2011 ok thanks alot i just picked up some front wrx calipers now i just need to find some rotors and pads! Link to comment Share on other sites More sharing options...
Zues Marine Posted June 6, 2011 Share Posted June 6, 2011 ^ and caliper brackets... while your at it get some SS brake lines and "ebc greenstuff" brake pads... theres some stopping power for yuh Link to comment Share on other sites More sharing options...
jayjay Posted June 28, 2011 Author Share Posted June 28, 2011 finally got around to installing my front wrx calipers today and realized the only difference between my stock caliper and the wrx is the bracket. My question is i thought the caliper itself was suppose to be bigger and not just the bracket? Also i looked up and found out that 02 wrx and 04 wrx have different calipers, would the 04 caliper be larger? Link to comment Share on other sites More sharing options...
mattcasey Posted June 29, 2011 Share Posted June 29, 2011 Theyre the same size caliper but you upgraded from floating to fixed. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 29, 2011 Share Posted June 29, 2011 ? upgrade? out cars are stock 2 pot floating calipers. you mean 2 pot fixed? we told you you needed bracket and caliper. Link to comment Share on other sites More sharing options...
jayjay Posted June 29, 2011 Author Share Posted June 29, 2011 ? upgrade? out cars are stock 2 pot floating calipers. you mean 2 pot fixed? we told you you needed bracket and caliper. you dont need a caliper all you need is the bracket... I noticed that the lgt and 02 wrx have the same part # for the caliper, but the 04 wrx is a completely different part # what is the difference with the 04 caliper? Link to comment Share on other sites More sharing options...
