98LGTLover Posted June 4, 2011 Share Posted June 4, 2011 So I have a 1996 Legacy L wagon and I was wondering if I could drop a 2.5 in it. Will the 2.2's ecu work with it and will the transmission work with it? The tranny is an automatic. The engine is a JDM EJ254. This question is for a guy who is wanting to buy my Legacy and put that engine in it. Link to comment Share on other sites More sharing options...
subikid90 Posted June 4, 2011 Share Posted June 4, 2011 It will bolt up and everything but that motor is single cam I believe, so that means that he will have to do a wiring merge with the single overhead cam ECU and engine harness. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
97400obw Posted June 5, 2011 Share Posted June 5, 2011 It will bolt up and everything but that motor is single cam I believe, so that means that he will have to do a wiring merge with the single overhead cam ECU and engine harness. Just curious but why would you have to merge wiring harnesses? I can see where there may be some differences in the wiring since the EJ254 is a much newer engine but the cams shouldn't matter. I swapped a 2.5 DOHC with a 2.2 SOHC and it all plugged in and worked just had to change out the Y-pipe since the 2.2 was single port exhaust. From what I understand the ECU can be reset and relearn which is nothing more than unhooking the battery for a while. Of course it may be different with the difference in yrs. I guess..... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 5, 2011 I Donated Share Posted June 5, 2011 I love how the interweb is full of bad information lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted June 5, 2011 Share Posted June 5, 2011 I've heard only good things about the 2.2L. Why would you even want to change it? Heck, just mod your 2.2 Link to comment Share on other sites More sharing options...
98LGTLover Posted June 5, 2011 Author Share Posted June 5, 2011 I said that the question was for a guy that is wanting to buy my old L wagon and do that... The car doesn't have a 2.2 to mod since there is no engine in it, which is the reason I asked about the JDM 2.5 getting dropped in it. Link to comment Share on other sites More sharing options...
johnegg Posted June 5, 2011 Share Posted June 5, 2011 if the ej254 is a SOHC and a phase 2 engine it will not be a plug and play. there will be wiring issues. most folks do not cross the phase 1 / phase 2 line. it is just too much work. but a 96 - 98 ej25 will drop in just fine. or put the ej22 heads / intake on the ej254 and install it. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted June 5, 2011 Share Posted June 5, 2011 So I have a 1996 Legacy L wagon and I was wondering if I could drop a 2.5 in it. Will the 2.2's ecu work with it and will the transmission work with it? The tranny is an automatic. The engine is a JDM EJ254. This question is for a guy who is wanting to buy my Legacy and put that engine in it. ^^^ I'd have understood your question if you'd have mentioned that the L Wagon HAD NO ENGINE TO start with. Even the guy in the post above this one says to use 1/2 of the 2.2L motor....like you still have it or something. I know he would have just recommended to get the 2.5 harness vs try to work with 2 diff engines that he thinks you already have. Link to comment Share on other sites More sharing options...
subikid90 Posted June 5, 2011 Share Posted June 5, 2011 A SOHC ECU wont run a DOHC cam motor and vise versa. You have to swap ECUs which requires rewiring. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
ehsnils Posted June 5, 2011 Share Posted June 5, 2011 Closed as per OP request. Link to comment Share on other sites More sharing options...
