LewisI Posted May 10, 2011 Share Posted May 10, 2011 I have a 2008 Legacy which was mostly parked for about 4 weeks, Today after starting the engine it died and now the starter motor turns but not the engine. Is it possible that the battery has no sufficient power? or is there definitely something wrong with the starter? what should I do? I appreciate any help thanks Link to comment Share on other sites More sharing options...
citka Posted May 10, 2011 Share Posted May 10, 2011 Potentially a bad solenoid. Sometimes when they go bad, they won't engage the starter gear so the motor simply spins without interfacing the flywheel. Try it a few times and see if it engages. Link to comment Share on other sites More sharing options...
LewisI Posted May 10, 2011 Author Share Posted May 10, 2011 I have tried several times but as you say the starter does not engage the flywheel, what would be the next step, remove starter? thanks Link to comment Share on other sites More sharing options...
dwolson2 Posted May 10, 2011 Share Posted May 10, 2011 take it in for warranty, thats really fast for a starting component to go out(3 years!) Link to comment Share on other sites More sharing options...
LewisI Posted May 10, 2011 Author Share Posted May 10, 2011 Im out of warranty with almost 58 kmiles. I jumped started the car and it worked fine, I guess the battery was too low due to having the car parked for too long. I went for a short trip and it starts fine. I will make now some long trips to recharge the battery. Im glad it works for now. Link to comment Share on other sites More sharing options...
citka Posted May 10, 2011 Share Posted May 10, 2011 Check out "Battery Tender." Well worth the money for a vehicle that sits. I have many of them for bikes, boats, the SUV that never gets driven above $4 a gallon... Link to comment Share on other sites More sharing options...
dwolson2 Posted May 11, 2011 Share Posted May 11, 2011 Check out "Battery Tender." Well worth the money for a vehicle that sits. I have many of them for bikes, boats, the SUV that never gets driven above $4 a gallon... +1 we use these in the shop all the time. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 11, 2011 Share Posted May 11, 2011 I use on for my Raptor 660R b/c it sits for long period btwn uses and everytime I push the start button she fires right up !! Link to comment Share on other sites More sharing options...
