leg5spd Posted May 5, 2011 Share Posted May 5, 2011 I'm having trouble with my front windows, They roll down all the way... but only roll up a quarter of the way, I've read that replacing the master window switch could solve the problem, though i tried another switch out of a functioning (97) and it did not help, what could be the problem, oh and fiddling around drained the battery twice( yeah I didn't learn the first time) Now the Check engine light is on... Link to comment Share on other sites More sharing options...
98LGTLover Posted May 5, 2011 Share Posted May 5, 2011 CEL will come on if the battery is really low like that, happened to me and the gauges were tweaking out and it was idling weird. Have you thought about the motors for the windows being bad? Maybe there isn't enough strength for the motors to push the window back up. Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 I'm pretty sure the motors are good, after messing around with the switch the drivers side finally decided to come up, the passenger side not so much... I ordered a newer master switch anyway Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 5, 2011 I Donated Share Posted May 5, 2011 The window regulators need to be replaced. Its NOT the switch -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 is it possible to repair the window regulator? otherwise I will just keep the windows up for now as they are both finally up... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 5, 2011 I Donated Share Posted May 5, 2011 Not that I know of. I've never seen anyone repair one. They are cheap enough to just replace usually -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 though would it be common for both front windows to go out at the same time? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 5, 2011 I Donated Share Posted May 5, 2011 So they both started acting up at the same time? Do the back windows do the same thing? If you're draining your battery that quick, maybe you have a bad cell in it, or the alternator isn't charging it. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 today was a nice day (first one this year) so I decided to roll the windows down then when I parked... they went up a quarter ways (made me suspect that they either weren't getting enough power or the switch was acting up) The rear windows seem fine though I did not lower them all the way (in fears of all four windows being stuck down) I went to the auto store and had the battery and alternator checked out and they were both behaving normally. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 5, 2011 I Donated Share Posted May 5, 2011 get out the multi meter and check the voltage at the window regulators. see if they are getting 12+ volts......I think it should be about 12.8 volts -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 well I suppose that would be a good thing to buy... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 5, 2011 I Donated Share Posted May 5, 2011 if you're getting the 12v at the regulator, then its the regulator thats bad. have you tried operating each window on its own switch instead of just trying them from the master switch on the drivers door? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
leg5spd Posted May 5, 2011 Author Share Posted May 5, 2011 I have tried at the doors, I can roll them down about halfway and up again without worry but beyond that they decide they only want to go up and down a quarter ways Link to comment Share on other sites More sharing options...
