TrentonJ Posted May 2, 2011 Share Posted May 2, 2011 I just bought a 1990 legacy wagon with 205000 miles Problems- -None of the dash lights work - I don't know what kind of stereo it has in it but its missing the face plate -The back passenger window doesn't roll down and the front passenger will roll down with the drivers controls but wont roll back up and if anyone knows problems that are common with the year let me know. will have pictures up soon something with wrong with the unloaders in the site. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 18, 2011 I Donated Share Posted May 18, 2011 You will have to take the radio out and look at the back or top of it to get the make and model number of it. You can usually find a replacement faceplate on ebay. When you say none of the dash lights, do you mean that the numbers dont light up? Does the ebrake light work, or any of the other dummy lights? If this is the case, there is a yellow wire behind the radio thats suppose to be grounded out. If it got cut when someone put the radio in, your gauges won't light up -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 18, 2011 Share Posted May 18, 2011 Or it could be the bulbs burned out, but I'd be hard pressed to believe all of them went out at the same time. Chances are it's something wrong with the illumination system. But on the off chance that all the bulbs burned out they're easy enough to replace. Link to comment Share on other sites More sharing options...
TrentonJ Posted May 19, 2011 Author Share Posted May 19, 2011 All of the dummy lights still work. I will try that with the radio Do ether of you know where i might be able to find performance parts for it? I finally got some pictures up too! Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 20, 2011 Share Posted May 20, 2011 Honestly performance parts will need to come from other Subaru's. Legacy's after the year 91 can use the rear sway bars from newer Legacy's and get a serious upgrade, but the 90-91 cant use the RSB's from newer ones so if we want that as a suspension upgrade you have to go with Whiteline. A lot of people like Whiteline for their suspension parts. I'd check them out for that stuff. As for rims/tires I'd go with some 02-05 WRX rims. They come 205/55/16 stock so it's an instant upgrade. It does rub sometimes off-road though. I've ripped quite a bit of my wheel well coating off. Engine-wise there's not a whole lot you can do...or at least I wouldnt with an engine that has 205k miles on it. I'd focus on making it handle better. Now does the passenger side window roll up with the passenger side control? Because that's what my driver side rear does. Link to comment Share on other sites More sharing options...
Baddog Posted May 21, 2011 Share Posted May 21, 2011 If it's power windows all around. Try and go to the junkyard and just replace the switch. My passenger window would roll down but not up till I replaced the switch. Give that a shot. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 21, 2011 I Donated Share Posted May 21, 2011 Judging by how your dummy lights still work but the gauges don't light up, my bets are on that ground wire. Same thing happened in my Legacy -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
TrentonJ Posted May 22, 2011 Author Share Posted May 22, 2011 Thanks for the performance info i will be getting those rims right quick.my passenger window will roll down with the drivers controls and passenger controls,but will only roll up with the passengers controls.yea i am gonna check that ground wire today and will see if that works.thanks for all the info guys BIGGG help lol Link to comment Share on other sites More sharing options...
TrentonJ Posted May 23, 2011 Author Share Posted May 23, 2011 well i took the radio out and the wire was grounded.so i replaced the fuse for the illumination system.it worked i was totally stoked but then 2 mins later they went back out.so i am stumped Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 23, 2011 Share Posted May 23, 2011 Did the fuse pop again? Link to comment Share on other sites More sharing options...
TrentonJ Posted May 23, 2011 Author Share Posted May 23, 2011 no i checked it,it was fine idk what the problem is now but i am gonna take it to my old man and see if he can MacGyver it Link to comment Share on other sites More sharing options...
Legacy Wagon Posted May 23, 2011 Share Posted May 23, 2011 Haha! Well, good luck man. Let us know. Link to comment Share on other sites More sharing options...
