NickTej22 Posted May 10, 2011 Author Share Posted May 10, 2011 but what i've been saying is I have a cel code for p0115 coolant temp sensor malfunction which means it wont start when hot and rough idle from what i've heard and seen in other threads and videos, they seem exactly like my symptoms and with the same p0115 code. As I said in the other posts or threads I replaced just about everything in the fuel system. Link to comment Share on other sites More sharing options...
nmd003 Posted May 10, 2011 Share Posted May 10, 2011 I have to agree with the OP on this one. Obvious solution is to replace the coolant sensor. It needs to be done regardless of whether or not it is the root cause of the problem, though I think it very well could be. If that doesn't work, then take it to the shop. Link to comment Share on other sites More sharing options...
NickTej22 Posted May 10, 2011 Author Share Posted May 10, 2011 Agreed, have you had this happen to you or know the symptoms? That's my main thing, while I sit and wait for payday to do this, I don't want to get my hopes way up. Link to comment Share on other sites More sharing options...
NickTej22 Posted May 14, 2011 Author Share Posted May 14, 2011 Fixed all those problems however my alternator is burning hot.. I'm really good at handling heat but this is too hot.. I. Noticed my fusible link melting, I unplugged my alternator and the link stopped meltng, plugged it back in and it was melting again however the alternator testedperfect at the parts store. Wha is this? Link to comment Share on other sites More sharing options...
NickTej22 Posted May 14, 2011 Author Share Posted May 14, 2011 Bump Link to comment Share on other sites More sharing options...
nmd003 Posted May 14, 2011 Share Posted May 14, 2011 This is beyond my scope of knowledge, but I'm glad you got your other issues fixed. Did replacing the coolant sensor fix it? Link to comment Share on other sites More sharing options...
NickTej22 Posted May 14, 2011 Author Share Posted May 14, 2011 Yup, the sensor failing choked the motor with fuel and killed my spark plugs and seized them, once I got that it ran better then it every has since I've owned it, except for my new problem lol. Link to comment Share on other sites More sharing options...
NickTej22 Posted May 14, 2011 Author Share Posted May 14, 2011 Bump again Link to comment Share on other sites More sharing options...
NickTej22 Posted May 14, 2011 Author Share Posted May 14, 2011 Bump again. Link to comment Share on other sites More sharing options...
NickTej22 Posted May 15, 2011 Author Share Posted May 15, 2011 And again. Link to comment Share on other sites More sharing options...
