nmd003 Posted April 26, 2011 Share Posted April 26, 2011 When I turn the steering wheel to the right while driving, there seems to be some sort of binding or something. It is worse at slower speeds than at higher speeds. The worst is probably while turning the wheel to the right while in reverse. There is absolutely no problem while turning the wheel to the left. I'm not 100% sure, but it seems like it may lower my RPMs a bit more than the power steering usually would while at idle. It seems like it may also somehow have had something to do with a misfire I had in cylinder #3 while I was backing out of a parking spot with the wheel turned to the right. The car didn't do this before the EJ22 was swapped in. Just wondering what is causing this and how to fix it. I look through a few threads but didn't come up with any concrete info. Really hoping to get these loose ends tied up. Finally got the engine running right. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 26, 2011 Share Posted April 26, 2011 Is this only occuring when you turn the wheel to the right? It sounds a lot like torque-bind to me. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted April 26, 2011 Share Posted April 26, 2011 Bad CV joint causing binding in one of the axles??? Link to comment Share on other sites More sharing options...
nmd003 Posted April 26, 2011 Author Share Posted April 26, 2011 torque-bind does seem like a candidate cuz it clearly slows the engine down when it happens. Someone on here said that they put a tube of transx in with the ATF and it fixed it completely, others mentioned draining and refilling the ATF 3 times with driving in between to fix it. I will try the FWD fuse and see if I can get some more info from testing it that way. Link to comment Share on other sites More sharing options...
nmd003 Posted April 27, 2011 Author Share Posted April 27, 2011 Didn't try the FWD fuse but my ATF is brown. Was supposed to get it serviced today, but it has to wait till tomorrow for the filter to arrive. Keeping my fingers crossed that this will fix it. Link to comment Share on other sites More sharing options...
Lojasmo Posted April 27, 2011 Share Posted April 27, 2011 Have a similar problem. Going to ignore it. Until something breaks, so that i will have incentive to put on my STI springs, struts, and front WRX brakes. (note to self: order your SS break lines.) Transmission fluid just changed. Link to comment Share on other sites More sharing options...
nmd003 Posted April 27, 2011 Author Share Posted April 27, 2011 Waiting for your tranny or center diff to shatter to give you incentive to do some brake and suspension work? lol Link to comment Share on other sites More sharing options...
Lojasmo Posted April 27, 2011 Share Posted April 27, 2011 Waiting for your tranny or center diff to shatter to give you incentive to do some brake and suspension work? lol It's something in the front suspension. Worn bushings, or a wheel bearing. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted April 28, 2011 I Donated Share Posted April 28, 2011 Have a similar problem. Going to ignore it. Until something breaks I will be shocked if your car last at all. Cars that last a long time are cars that are owned by people who take care of problems before they become major issues. Good luck -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
nmd003 Posted April 29, 2011 Author Share Posted April 29, 2011 ATF was black, bunch of crud down in the pan, and the pan was glued to the tranny instead of having a gasket. Got everything cleaned up, put new fluids in it and a tube of AMSOIL limited slip additive. Problem already feels less severe and seems more intermittent. On another note, my headlamp went out on me. Link to comment Share on other sites More sharing options...
Lojasmo Posted April 29, 2011 Share Posted April 29, 2011 I will be shocked if your car last at all. Cars that last a long time are cars that are owned by people who take care of problems before they become major issues. Good luck Sort of tongue in cheek. Doing my suspension and brakes on my next long weekend. Will have a goog look around The front end while I am in there, and order whatever worn bushing is causing my clunk. In the four months I have had my car: Replaced all seats with leathers Replaced washer res. Replaced broken side mirror. Replaced driver side window gasket Oil change Tranny fluid change Rear diff change Replaced all wiper arms Happy? Edit: mine is not torque bind, for sure. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 30, 2011 Share Posted April 30, 2011 ATF was black, bunch of crud down in the pan, and the pan was glued to the tranny instead of having a gasket. Got everything cleaned up, put new fluids in it and a tube of AMSOIL limited slip additive. Problem already feels less severe and seems more intermittent. On another note, my headlamp went out on me. Amsoil does a good ls additive, good choice. You'll probably need to do a tranny rebuild sometime down the road though. And there's always another problem to look forward to, eh? Link to comment Share on other sites More sharing options...
nmd003 Posted May 2, 2011 Author Share Posted May 2, 2011 Amsoil does a good ls additive, good choice. You'll probably need to do a tranny rebuild sometime down the road though. And there's always another problem to look forward to, eh? No kidding. Makes me wish I went to auto school so I'd be better at all this work I've been doing on the car. I'm doing okay for reading stuff on the interwebs and trying to wing it. I have a lack of proper tools though for sure. Only so much a craftsmen set can do lol. And PO put new tires on the back but not the front, just lovely. Not even the same brand. Uniroyals on front methinks and Kumhos on the back Could sell the car and turn a profit, but I'm kinda getting attached after replacing the engine and all lol. Link to comment Share on other sites More sharing options...
nmd003 Posted May 2, 2011 Author Share Posted May 2, 2011 PS put 500 miles on it this weekend; drives much better now for sure. Torque-bind seems to be completely gone as far as I can tell at the moment. Also got a good chance to let the HLAs pump up and all. Not impressed with power compared to the EJ25D, but reliability takes precedence. Link to comment Share on other sites More sharing options...
kaz98gt Posted May 2, 2011 Share Posted May 2, 2011 what year is the 2.2? you may not have HLAs on that...mine is from 97 and it's MLAs all around. Link to comment Share on other sites More sharing options...
nmd003 Posted May 2, 2011 Author Share Posted May 2, 2011 95. HLAs for sure. Link to comment Share on other sites More sharing options...
