bmx045 Posted April 29, 2011 Share Posted April 29, 2011 stock Link to comment Share on other sites More sharing options...
GTTuner Posted April 29, 2011 Share Posted April 29, 2011 Walbro, 5 years ran flawlessly. I recently replaced it as a preventive measure. I took the old one a rigged it on my rider mower with meth and a 50 hp shot of NOS. I pop wheelies while mowing the lawn. Link to comment Share on other sites More sharing options...
rao Posted April 29, 2011 Share Posted April 29, 2011 boost pump eh? stock lgt or sti? bmx 45 what pump are you running? Stock Legacy fuel pump, with the BAP it has plenty of capacity for most turbos. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
kingsteve Posted May 8, 2022 Share Posted May 8, 2022 (edited) This isn't the "Connect the pink wire together" sort of thing. For some reason the ECU is seeing a problem in this circuit. You need to track down why this is happening. Here is the complete diagnostics procedure. There is not much to it. Get out your multimeter and get busy. I am having a problem with DTC P0230 and was happy to find this post with a diagnosis procedure. My car failed Steps 4 and 6, which test the fuel pump control unit terminals 6, 7, 8, and 9 to chasis ground. Success criteria is resistance > 1Megaohm and I was reading <0.5Megaohms. It would seem that the FPCM is the culprit. Would the fix be as simple as just swapping it out? I checked all the wires I could and did not see any exposed wires that may be unintentionally grounding. Is there anything else I should be checking? I have tried to do my research and want to be sure before ordering the part. Help is very appreciated! Thanks Edit: The car still runs with P0230 CEL. Other posts I've seen with similar issues describe the car won't start. Edited May 8, 2022 by kingsteve more background Link to comment Share on other sites More sharing options...
