1-3-2-4 Posted May 13, 2011 Author Share Posted May 13, 2011 well haha I broke my OBDII adapter when i was getting out to get gas my leg hit it and broke the plastic part that plugs in and bent some pins.. but it's cool because I plan on trying that all blue one that's smaller like your OBD key. hopefully it will work better. Speaking of that your MPG does not show up right? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 13, 2011 Share Posted May 13, 2011 No, our cars don't calculate it. However, I think torque calculates its own MPG based on engine load and stuff or something, though I have yet to mess with it. Link to comment Share on other sites More sharing options...
MatsuDano Posted May 13, 2011 Share Posted May 13, 2011 Engine load, displacement, distance, and tank. It surprises me how accurate they are with measurements that are calculated rather than reported. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted May 13, 2011 Author Share Posted May 13, 2011 ah thanks, I never had it up long enough.. I guess you need to do a long trip for it to start showing info? Anyways I'm going to get this one next http://product.madeinchina.com/ELM327-Bluetooth-OBD-II-Wireless-Transceiver_12909990.shtml whatever you do don't leave any of them plugged in they still draw power from the port the developer for torque says no one has complained about the all blue one yet that he knows of. Link to comment Share on other sites More sharing options...
crackunia Posted November 27, 2014 Share Posted November 27, 2014 Try these steps. It's a little redundant and you may have already attempted, but this is the first step in tech support, right? 1. Go to settings>wireless>bluetooth settings>find the device, long press and unpair. 2. Disable bluetooth. 3. Enable bluetooth. 4. Tap "Make Discoverable". 5. Scan for devices, but do not try to pair the device at this point. 6. Launch Torque 7. It should find the bluetooth signal and try to connect, asking for the prompt. At which point you enter in 6789. 8. Check it again. I'll keep digging to see what else it could be. I'm also in CT and I have a similar setup. Maybe I can even come out to see it. PM me if interested. Hi there got same problem! I have 2005 Subaru Legacy GT Spec B imported from Japan. Got ELM327 receiver. phone says its connected to OBD II bluetooth receiver and also to CPU. but most gauges shows "no data". I tried to unpair and pair via torque pro but nothing changed. here are some screens http://s018.radikal.ru/i510/1411/a3/208a5df5dd6f.png http://s018.radikal.ru/i502/1411/2a/6c597c0731e0.png any other solution? Link to comment Share on other sites More sharing options...
twisty Posted December 1, 2014 Share Posted December 1, 2014 if its a jdm, it may not be supported for reading. my 95 has the basics, but not all the info is available. i always assumed it just wasnt made available to scanners, since the same info doesnt come up with my snap on scan tool as well. Link to comment Share on other sites More sharing options...
