1-3-2-4 Posted September 30, 2017 Share Posted September 30, 2017 I can offer you this from an eBay vendor. I have a 2007 limited and these are the instructions I was given. I attached a pic of the fob so you can compare too. Programming for a 2006 to 2008 Subaru Legacy * Read through this information very thoroughly as eveything needs to be done in a quick fashion!* This is a very difficult procedure that many / most folks are just not able to perform well or properly. While we provide this information, we recommend a dealer or very good locksmith for the programming of these due to the difficult nature of the process to get these going. * First, open the remote and make a note* of the eight-digit number located inside the case. * * When * ***** Remote transmitter added or replaced. ***** System malfunction. * * How * * NOTE: A maximum of 4 remote transmitters can be programmed (one at a time). * Program all 4 memory positions to ensure lost or stolen remote transmitters * will not work. * ***** Locate and record remote transmitter ID number from package or remote ***** transmitter that will be programmed. ***** Open driver's door. ***** Enter vehicle. ***** Close driver's door. ***** Within 15 seconds: Turn ignition key to ON position and back to LOCK ***** position 10 times. ***** An acoustic signal is emitted once to indicate programming mode activated. ***** Another continuous acoustic signal will follow and interior lamp will flash ***** until programming is complete. * * NOTE: If an error occurs during programming, the acoustic signal will stop, the * interior lamp will extinguish and the programming will need to be started * again. * ***** Within 45 seconds: ***** Open driver's door. ***** Close driver's door. ***** An acoustic signal is emitted until the ID number is entered. ***** Press the LOCK button on the door control panel the same number of times as ***** the first digit in the remote transmitter ID number. ***** When the digit has been entered press the UNLOCK button on the door control ***** panel. ***** Repeat procedure with each digit counting from left to right. ***** Repeat programming procedure for the entire ID number a second time. ***** An acoustic signal is emitted once to indicate programming complete. ***** Repeat ID number entering procedure for any additional remote transmitters ***** being programmed. ***** Check operation of all programmed remote transmitters. http://www.keylessremotesonline.com/images/1193444824847-503728209.gif I think my battery in my remote is dead...if I understand right do the first left most number then unlock then do the rest unlock until you do all the numbers then repeat and when done the light stops flashing and the door locks on it's own? Maybe because I did not leave the key in the on position? battery checked out at 3V but I changed it anyways so the new one is 3.3V Link to comment Share on other sites More sharing options...
