joepaco Posted March 26, 2011 Share Posted March 26, 2011 so i ordered an aem piggyback and i have been searching around if anyone has tried it in 1998 legacy L all i found so far is ppl using it un 01 2.5RS can anyone guide me to the correct thread or if you have personally used the aem let me know how it worked out ill be getting mine on monday i have been trying to get the apex i safc to work on my car but no luck so i decided to get the aem Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 27, 2011 Share Posted March 27, 2011 Ive never ran across anyone using aem, honestly I didnt even know that they made one.. Ive only seen people using emanage, pp6, and apexi so i could just be out of the loop. That or its jsut not very popular in legacys Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 27, 2011 I Donated Share Posted March 27, 2011 No many people run piggyback systems on our cars. Generally, those who run something special have a turbo swap and they run the WRX or STI ECU. There are a few out there however that run stand alone ECUs. I have a Megasquirt 1 stand alone ecu in mine....but I'm not using an EJ22 or EJ25. I'm running an EJ20R with a TD04 turbo, 252 cams, MSD, and a bunch of other gooides. Are you just going to use base maps or are you going to get a pro tune? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Zues Marine Posted March 27, 2011 Share Posted March 27, 2011 use the pp6 Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 27, 2011 I Donated Share Posted March 27, 2011 use the pp6 he already ordered the AEM -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted March 27, 2011 Share Posted March 27, 2011 PP6 is hell to get a hold of. Link to comment Share on other sites More sharing options...
Zues Marine Posted March 27, 2011 Share Posted March 27, 2011 because its awesome Link to comment Share on other sites More sharing options...
Baddog Posted March 27, 2011 Share Posted March 27, 2011 Yeah I have heard good things. I will eventually get something for Piggyback for when I am done with my all motor build. That way I can get some more juice out of it. Link to comment Share on other sites More sharing options...
subikid90 Posted March 27, 2011 Share Posted March 27, 2011 use the pp6 -1 Rallitek told me last week that they no longer will support anything to do with them. You cant even get instruction on installing them anymore. The PP6 was a very good system but since Ralitek no longer supports it, it wont do you much good if you need help. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted March 27, 2011 Share Posted March 27, 2011 but theres plenty-o-support via forums, specifically rs25 on all things pp6 Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 27, 2011 Share Posted March 27, 2011 96Imprezadent on nasioc has a ej22t with aem. You could talk to him about it, thats better then nothing.. I should say at one point in 2005 he did, but the forum posts are still live. http://forums.nasioc.com/forums/showthread.php?t=900404 Link to comment Share on other sites More sharing options...
joepaco Posted March 27, 2011 Author Share Posted March 27, 2011 thanks for the link i will wire it tomorrow and see how it goes ill keep everyone posted i ran at english town today ran 14.92 best run i had a full tank of gas my best so far is 14.82 at 6psi hopefully i can tune this thing with the aem heard there is some problems with the missing tooth crank and cam sensors but ill figure something out the aem piggy back is only 350$ and it does timing and fuel for up to 6 cil if you had one ill keep everyone post it of it is never a bad thing to try new things get away from the me too stuff Link to comment Share on other sites More sharing options...
joepaco Posted March 29, 2011 Author Share Posted March 29, 2011 so i installed the aem piggyback last night i had a problem with it cutting out around 3000 rps under load i installed a 2.2k ohm resistor on the cam an crank sensor wirers (if anyone doing the piggyback let me know ill tell you where to put it at) so far running good i havent tuned anything yet i see the i can tune timing, fuel, maf signal and i have analog A and analog B i dont have anything conected to it right now im going to run the aem for a while before i start changing things if anyone knows whats the max voltage that our maf sees in wide open thortle please let me know i havent got any second gens to the shop and mine is boosted so it wont work or if anyone near mtholly nj let me know so i can plug in the comp and check so far it seems that it was well worth 350$ thank you ill keep posting any changes Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 29, 2011 Share Posted March 29, 2011 Check this badboy out. Im pretty sure in one of those pages it tells you maf voltage info. http://www.rs25.com/forums/f7/t107798-phase-ii-2-2l-map-turbo-conversion-parts-list.html Link to comment Share on other sites More sharing options...
joepaco Posted March 30, 2011 Author Share Posted March 30, 2011 thank you for the link ill get on that, is alot of pages lol but ill find it i mess with the timing a lil today and it spuder alil it ran 15.18 i installed the jumper harness and it ran 14.73 best time do far at 89 mph 1.98 60 ft Link to comment Share on other sites More sharing options...
joepaco Posted April 2, 2011 Author Share Posted April 2, 2011 so i've been running the piggy back for couple of days so far no problems with it besides a wire i didn't hook up all the way in the plug thats the reason it was sputtering this week end im gonna install the 02 sensor bong and get the wide band in there so i can tune the fuel i was thinking 12:1 anyone know whats a good egt number for this car at what a/f ratio? or is it around 12:1 Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 2, 2011 Share Posted April 2, 2011 Ive heard MAP cars like 12:1 and maf is more like 6-8:1. But I can not confirm that! I actually read it in the link I posted a few days ago! Im putting on a vortech fmu in place of my craptastic ebay rrfpr. Its 12:1 too Link to comment Share on other sites More sharing options...
joepaco Posted April 2, 2011 Author Share Posted April 2, 2011 how much for it i might be intrested Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 5, 2011 Share Posted April 5, 2011 Which aem are you using exactly? My fuel pressure at idle is 40 psi and rises to a max of 45. No vac leaks. Its retarded. Link to comment Share on other sites More sharing options...
joepaco Posted April 5, 2011 Author Share Posted April 5, 2011 im using the FIC-6 piggyback i found videos on youtube from aem that explain how to use the piggyback and how it works Link to comment Share on other sites More sharing options...
joepaco Posted April 7, 2011 Author Share Posted April 7, 2011 so ive been searching for a miss i got the last few days and could not figure it out, i found the cam and the maf wire on the aem plug came out of the plug the plug is very cheap made and cant hold the wires i put the wire back in and put some super glue in the back so it stop from coming out so far its working fine i tuned the car at 12 to 1 air fuel ratio when i put the wide band in it was at 10 to 1 some time 9 to 1 lol i ran 14.73 with the mixture super rich im hoping to get better number now even tho the temp is going up Link to comment Share on other sites More sharing options...
PNW_AWD Posted February 23, 2017 Share Posted February 23, 2017 has anyone else attempted a AEM? Link to comment Share on other sites More sharing options...
