papp101 Posted March 16, 2011 Share Posted March 16, 2011 So I'm assuming this won't work, but I'd like to hear anyone's thoughts on this. I'm a bit stuck right now from a cost perspective - I have a 2005 lgt with the stock 5mt tranny - I need to swap the clutch as it's starting to slip a bit. I bought an 06 WRX flywheel and had it machined. then I purchased an ACT HD street DISK. Now I need a pressure plate, throwout bearing, pilot bearing and alignment tool. Does anyone know if I can use my stock pressure plate? I'm just looking for a step above stock, no real launches or drag racing. If not, will a used 06 wrx pressure plate be fine? I really appreciate the help! Link to comment Share on other sites More sharing options...
rao Posted March 16, 2011 Share Posted March 16, 2011 It won't work. You need a 06+ wrx pressure plate or a 07+ Legaacy GT pressure plate Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
papp101 Posted March 16, 2011 Author Share Posted March 16, 2011 thanks rao! I just needed it confirmed. I will promptly source one! Link to comment Share on other sites More sharing options...
